Windows 7 Bsod Problem Help
Ivan Apostoloski
I have problem,every time i play games my pc turn off when the computer is restarted it says
Problem:Blue screen
Os version : something like this
this is minudump
041514-17409-01.dmp
BugCheck 116, {fffffa800a9a54e0, fffff8800fa49e2c, ffffffffc000009a, 4}
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by : nvlddmkm.sys ( nvlddmkm+9bbe2c )
Followup...
Problem:Blue screen
this is minudump
041514-17409-01.dmp
Hello and welcome to the forum.
While I will not be able to help much with respect to your actual problem, you should know that there are a few things that will be needed from you in order for someone to actually follow up with your post.
First make sure your machine is configured properly to facilitate the collection of .dmp files.
Go to Start and type in sysdm.cpl and press Enter
Click on the Advanced tab
Click on the Startup and Recovery Settings button
Ensure that Automatically restart is unchecked
Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box
Ensure that the Small Dump Directory is listed as %systemroot%\Minidump << where your .dmp files can be
found later.
Click OK twice to exit the dialogs, then reboot for the changes to take effect.
Then……Please read the first post in this sticky thread here Link Removed
Do your best to accumulate the data required.
Run the SF Diagnostic tool (download and right click the executable and choose run as administrator)
Download and run CPUz. Use the Windows snipping tool to gather images from all tabs including all slots populated with memory under the SPD tab.Likewise RAMMon. Export the html report, put everything into a desktop folder that you've created for this purpose, zip it up and attach it to your next post (right click it and choose send to, compressed (zipped) folder.
And you've double posted your problem. Hopefully one of the staff members will be along shortly to clean up that issue.
please follow Trouble's excellent advice. We need to see an actual dump file in order to debug.
I've also merged your posts to save confusion.
Followup: MachineOwner
it looks like your GPU driver may have been the culprit as both dump files you sent were the same.
Try uninstalling your GPU driver using this application:
That will remove any old bits of driver left lying around. Re-install latest version:
http://www.nvidia.com/Download/index.aspx?lang=en-us
BiosVersion = AC3F1020
BiosReleaseDate = 02/23/2011
Your Bios has updates too. Please make sure I have the correct motherboard:
athurx.sys Thu Oct 06 11:10:34 2011: Atheros AR9271 Wireless Network Adapter please update:
dtsoftbus01.sys Thu Jun 20 08:22:51 2013: Daemon Tools driver. Possible BSOD issues in Win7 uninstall to test.
Run the Intel driver utility:
Rt64win7.sys Tue Aug 27 07:06:06 2013: Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet please update:
Post any new dump files.
I've also merged all your posts together please stick to one thread.
