If you're able to run commands when it's "locked up" it's probably just an application hanging. If you open task manager and go to the details tab. If the video hangs again right click on the process associated with the player and select 'Analyze Wait Chain' if there is anything listed in the Windows post a screen shot.
- Joined
- Jul 4, 2015
- Messages
- 8,998
I don't see any dump files. Can you check and manually upload any new ones. C:\Windows\Minidump.
I do see that your system failed to create a dump. You may want to turn off automatic manage page file and set it specifically for the C drive.
Page File: Link Removed
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #4
I had installed a keyboard driver but uninstalled it and have rebooted several times since. i've checked for malware and issues reported by glary ( none found ) there is nothing in the minidump folder at this time. I did just experience a freeze while watching a amazon prime video.. no BSOD just total freeze
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #5
lol I'm cursed.
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
C:\WINDOWS\system32>dism /online cleanup-image /restorehealth
Error: 87
DISM doesn't recognize the command-line option "cleanup-image".
For more information, refer to the help by running DISM.exe /?.
The DISM log file can be found at C:\WINDOWS\Logs\DISM\dism.log
C:\WINDOWS\system32>dism /online/cleanup-image/restorehealth
Deployment Image Servicing and Management tool
Version: 10.0.14393.0
Error: 87
The online/cleanup-image/restorehealth option is unknown.
Error: 87
Error: 87
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #6
I had another lock up ( not bsod ) just a few minutes ago, ran it right afterwards but I guess it didn't find anything wrong...
C:\WINDOWS\system32>dism /online /cleanup-image /restorehealth
Image Version: 10.0.14393.0
[==========================100.0%==========================] The restore operation completed successfully.
The operation completed successfully.
- Joined
- Jul 4, 2015
- Messages
- 8,998
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #10
I threw a BSOD on restart after running DDU but then worked on second restart. The display settings I think are wrong now however
I"m using a Hisense 40H3E with hdmi but windows is saying the monitor is s "generic pnp monitor" .
I mainly do Photoshop & lightroom so colorspace is critical
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #12
sorry to be a pest... another bsod and audio stutter.. this time it created a file even though the audio was stuttering.
update: after playing for 30 min I noticed the temps spiked a bit,
which is weird since I'm watercooled.
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #13
ok, i ran the online version of housecalls so there is nothing but defender currently for anti-virus, I went ahead and removed glary.. yes, I did ddu in safe mode, it rebooted to BSOD, rebooted again to running system..
on the event viewer idk what to look for nor where..
I don't see SearchIndexer running anywhere, not services nor processes.
There is a game I recently installed ( WarThunder) .. could that be causing issues?
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #15
just an fyi I tried to run driver verifer and it crashed on startup..
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: The system cannot find the file specified
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(String fileName)
at W7F_Diagnostic_Tool.Form1.Button2_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8745 (WinRel.050727-8700)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
W7F Diagnostic Tool
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Bear/Desktop/W7F%20Diagnostic%20Tool/W7F%20Diagnostic%20Tool.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.8745 (WinRel.050727-8700)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.8750 (QFE.050727-8700)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #16
i don't remember I thought I got them directly from asus. It's interesting that pcprobe is still showing because its not been installed for a very long time.
Apparently you can't use amd's chipset drivers without a radeon card, which honestly makes no sense..
I'm waiting to talk to asus right now to see what can be done about the pcprobe and inability to update the sata driver. Also find out if they have the latest chipset drivers.
Bear
Well-Known Member
- Joined
- Sep 29, 2016
- Messages
- 128
- Thread Author
- #20
last 24hrs has been good.. I purged all the usb drivers ( I found a generic one from a photography tethering app ) and then updated all the asus related drivers I could find. I think the sata one is still nerfed though, I can't seem to get it to update fully.
I removed warthunder, reinstalled it and was able to play all day heavily yesterday w/o a single issue, so I'm fairly certain its not warthunder. Nvidia released a update today also. I'm comfortable with the registry but just don't know which keys other then the ASIO key itself. I see the driver in the files but no uninstall... Is there a reliable free driver removal software?
Similar threads
- Article
- Replies
- 5
- Views
- 1K
- Article
- Replies
- 0
- Views
- 2K
- Replies
- 0
- Views
- 5K
- Replies
- 8
- Views
- 4K
- Article
- Replies
- 0
- Views
- 1K
