Bear
Well-Known Member
I'm still only running windows defender as requested in previous thread and suddenly the crashes have started again. When it triggers, its either a BSOD or total lockup of the system.
If you're able to run commands when it's "locked up" it's probably just an application hanging. If you open task manager and go to the details tab. If the video hangs again right click on the process associated with the player and select 'Analyze Wait Chain' if there is anything listed in the Windows post a screen shot.
Bear
Well-Known Member
so, its ok that that core voltage is dropping to .9?
nmsuk
Yeah thats fine and happening as you're using the balanced power profile, if you want it full on all the time, set the profile to high performance and they shouldn't drop at all.
