Windows 10 BSOD starting again.
Bear
Well-Known Member
I'm still only running windows defender as requested in previous thread and suddenly the crashes have started again. When it triggers, its either a BSOD or total lockup of the system.
If you're able to run commands when it's "locked up" it's probably just an application hanging. If you open task manager and go to the details tab. If the video hangs again right click on the process associated with the player and select 'Analyze Wait Chain' if there is anything listed in the Windows post a screen shot.
oh boy.. i SERIOUSLY don't want to start over yet again...
the only thing I can see is, to be honest I'm 99% sure its a issue with my install of 10.
Log Name: Microsoft-Windows-Kernel-PnP/Configuration
Source: Microsoft-Windows-Kernel-PnP
Date: 03-Sep-17 19:58:14
Event ID: 441
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Computer: BearsPC
Description:
Device USBSTOR\Disk&Ven_WD&Prod_My_Passport_259F&Rev_1014\575833314136365253503339&0 could not be migrated.
Last Device Instance Id: SCSI\Disk&Ven_&Prod_\4&fa535c2&0&020000
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FE00FFFFF130
Present: false
Status: 0xC0000719
Event Xml:
<Event xmlns="Link Removed">
<System>
<Provider Name="Microsoft-Windows-Kernel-PnP" Guid="{9C205A39-1250-487D-ABD7-E831C6290539}" />
<EventID>441</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2017-09-04T00:58:14.451384400Z" />
<EventRecordID>1675</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="380" />
<Channel>Microsoft-Windows-Kernel-PnP/Configuration</Channel>
<Computer>BearsPC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="DeviceInstanceId">USBSTOR\Disk&amp;Ven_WD&amp;Prod_My_Passport_259F&amp;Rev_1014\575833314136365253503339&amp;0</Data>
<Data Name="LastDeviceInstanceId">SCSI\Disk&amp;Ven_&amp;Prod_\4&amp;fa535c2&amp;0&amp;020000</Data>
<Data Name="ClassGuid">{4D36E967-E325-11CE-BFC1-08002BE10318}</Data>
<Data Name="LocationPath">
</Data>
<Data Name="MigrationRank">0xf000fe00fffff130</Data>
<Data Name="Present">false</Data>
<Data Name="Status">0xc0000719</Data>
</EventData>
</Event>
This is nuts, now the thumbdrive isn't recognized after doing chkdsk /r & rebooting. It's got to be something to do with the usb drivers I would think but I'm not sure how to remove ALL the usb devices to have them reconfigured since the kbd & mouse are usb also.
the drives are No longer on the hub so its not the hub.
weird part is it see's the passport but not the other 2
An image from 'BSOD starting again.'. Forum user discusses USB driver issues causing unrecognized thumb drive, while uninstalling USB driver.
but device manager see's all of them.
Since device manager see's them I don't think its a bios issue.
I'll have my son unplug everything but the kbd and mouse and put them in usb 2 since I doubt usb 3 is going to make a hill of beans difference.
any special settings in bios I should check?
I'm also going to uninstall avira yet again.
Hopefully this one tells you more.. once again dxdiag wasn't auto found so I created it manually, then reran telling it to skip everythign already written.
This time it happened within 60 seconds of starting pandora and a flash game ( soliders inc )
It said "clock watchdog timeout"
on the positive side of things, after removing all the stuff yesterday, drives are back! *shakes head in confusion*
I haven't had this much trouble with windows in a LOT of years.
idk, how relevant it is but I'm seeing 2 usb keyboards in bios, which is very strange.
Here's the usb listing from device manager..
An image from 'BSOD starting again.'. List of USB controllers, hubs, devices, and root hubs from device manager.
yes, .. so system was fine for a while, then 1709 came through and things went to hell in a hand basket.. after fighting for last 2 mo to get it fixed, MS screwed up and destoryed the uefi bootloader so I wound up having to do a brand new totally clean, new paritions etc install..
Today is first day and already got bsod ( and tons of other permissions issues ) 2x.
here's the latest
and the screenshot is from the one moments before it.
Hi, thanks for responding, I hadn't at that point because there are NUMEROUS install issues. I've got an appointment with level 2 MS tech tomorrow @ noon so hopefully they will figure out the TRUE root cause instead of bandaiding.
as for the build, yeah, i'm wondering about that.. I had hit a button in settings that apparently caused it, although now it says its not turned on, so idk..
I dont' suppose there is a way to rollback w/o reinstalling? Do I need/want to rollback?
An image from 'BSOD starting again.'. Screenshot showing Windows 10 Pro specifications with version 1709 and OS build 16299.192.
Appreciate your help guys.
Bear
BugCheck 1000007E, {ffffffffc0000005, fffff802f86b6424, fffffc8d6aaeb6a8, fffffc8d6aaeaef0}
Probably caused by : memory_corruption
Followup:     memory_corruption
Hi Bear,
did you apply any drivers?
You also need to run windows update.
Try these scans
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
I really have to hit the sack but will check back later.
oh, and just fyi kemical I did run both right after I sent the report here, and both revealed no issues.
sense then I've installed realtek's chipset audio drivers and nvidia's drivers.
I'll get lan done today. I'm not sure Asus's asmedia drivers are current since its been so long since asus updated them?
Hi Bear,
Try these scans
File scans
sfc /scannow
just had another one..
  • W7F_04-02-2018.zip
    W7F_04-02-2018.zip
thats odd.... could it be because I did a bunch of stuff after install before restarting ?
Macrium is one of the top backup systems there is.
BugCheck 1E, {ffffffffc0000005, fffff80069d30424, 0, ffffffffffffffff}
*** WARNING: Unable to verify timestamp for mrcbt.sys
*** ERROR: Module load completed but symbols could not be loaded for mrcbt.sys
Hi Bear,
this dump file is pointing to Macrium Reflect as the cause. Please uninstall to test.
taking macrium out didn't solve it.. I just had another and on reboot I checked hwinfo and noticed that core voltage on core 1 and 5 were VERY low..
I had a flash game, spotify and a dl going when it crashed this time. Seems to me spotify has caused it before and I read it has for others.
i just went into bios "optimized" it, made sure the energy saver was turned off and touched nothing else.. now voltages are up! it's set to "normal" in bios btw..
An image from 'BSOD starting again.'. CPU and memory usage, core voltages and clocks, and motherboard temperatures and voltages shown.
oh, I also uninstalled the nvidia drivers using ddu
grrr.. looks like they are going up and down depending on activity?
here's what they look like after nvidia was reinstalled ( no experience or 3dvision)
ok, now this is weird... just got a notice about updates that won't install..
[ATTACH type="full" align="right" alt="An image from 'BSOD starting again.'. 1. NVIDIA driver update status screen showing installation issues and pending media update.
2. CPU monitoring software displaying core voltages, clock speeds, and usage percentages."]35864[/ATTACH]
if it knows my drivers are better wth is it going to keep trying?
I just turned hwinfo on and this is what it shows..
2. CPU monitoring software displaying core voltages, clock speeds, and usage percentages."]35865[/ATTACH]
