Windows 10 BSOD Steam Games Problems
GipsyDanger
Member
I've had recent problems that when I am playing steam games my computer it often restarts with BSOD errors. It is mostly Memory Management errors but now it varies a lot. I've tried as many of the fixes as possible but it doesn't seem to work. I also found that the Network Controller couldn't be updated as windows couldn't find any drivers to update it with so I disabled it instead. It worked for a few hours but then it went again.
If anybody could recommend some drivers or tips on how to stop the problem it would be greatly appreciated.
Thank you for the update Gypsy, I'll keep my fingers crossed all goes well.
GipsyDanger
Member
Got the PC back today. They found out it was one of the RAM sticks causing the problem so they replaced it. I’ll see how it performs over the next few days
So it was the RAM after all... Thanks for the update and good luck with the new parts.
Just a query, did they replace both sticks or just the one?
4 sticks of RAM gives a total of 12GB?
Hmm... Well usually RAM comes in kits of either two or four sticks. These kits are matched in the factory to ensure compatibility so when one becomes faulty it's usually best to replace both sticks (or the four depending on set up).
Also ram nowadays (for pc) comes in either 8GB or 16GB sticks so what your saying does sound a bit unusual.
GipsyDanger
Member
What I’m trying to say is that only one of the two sticks of RAM were faulty so the working one was left in. Then two more new sticks were put in so there’s one old stick and two new sticks in the PC so three in total. Each one of the three is 4GB.
