Windows 7 Check of Win 7 partition with chkdsk from WinXP-BootCD possible?
pstein
Assume I want to check the partition NTFS integrity of a Win 7 system from a BootCD with WinXP.
Is this possible?
Or is the WinXP chkdsk utility outdated and NOT usable for Win 7 NTFS systems?
Peter
Windows 7 uses the same version of NTFS as XP NTFS v3.1 so it should work.
From an elevated command prompt you can verify the NTFS info with this command
fsutil fsinfo ntfsinfo C:
