Windows 10 Convert MBR to GPT without Data Loss
NettleWarbler
Honorable Member
When I try to delete the volumes the area is greyed out .
bochane
Location
Leiderdorp, The Netherlands
It is greyed out, because the MBR format of drive 0 don't allow you to use it.
Sorry, but as suggested before, please go to a repair shop and let they do it for you, they should also be able to answer all your questions directly.
Windows Forum Admin
Location
Room 237
As I posted before probably the easiest method is simply to wait until you want to re-install windows.
Boot from the media windows is on.
Start the install process and when asked find the drive you want windows on and delete all partitions.
Click next to start the install process and the drive will automatically be formated GPT.
Job done.
(must be a uefi capable system tho)
NettleWarbler
Honorable Member
kemical , i normally delete all partitons when loading windows , i didn't know you could get gpt that way . I disk management i delleted some volumes tried to get onto the drive i was getting automatic repairs for ages i must have done something wrong . Tried diskpart again i think it may be ok .
NettleWarbler
Honorable Member
When i right click on disk 0 in disk managment it says convert to mbr , so i will load windows later tonight and try . I will make a note of kemicals idea ( in case ) he took a lucky guess .
Windows Forum Admin
Location
Room 237
A lucky guess?
WTF?
I've been using this method since 2015.
Unfuckingbelievable.
NettleWarbler
Honorable Member
I always use that method , delete all partitions so theres only one space to load windows . Theres keep files and folders or custom install which I use it usuly ends up as mbr . Which it has
NettleWarbler
Honorable Member
It has keep files and folders , but I think something used to go wrong . It used to keep going back to install , so I just used custom install to save the hassle .
NettleWarbler
Honorable Member
bochane , was going to get me to take my hard drive to the computer shop . He may be right disk management converted it to gpt I have the feeling as soon as windows is installed it will be mbr . Unless some software does the job . Does anyone know of any way to convert to gpt , it don't matter about losing files or re-installing windows .
Windows Forum Admin
Location
Room 237
I fail to understand why you won't follow the link I posted above? Here it is again in case for some weird reason you can't see it:
Windows Setup: Installing using the MBR or GPT partition style
That is a method to format to GPT.
HOWEVER
If the above method is failing for you then you may have to consider your system isn't set up for uefi installs.
NettleWarbler
Honorable Member
It is set up for gpt , its all I now use . I like all the area in one without 2tb partitions , I wouldn't know where everything is stored . Would seagate disc wizard convert it to gpt . I didn't try the link .
Windows Forum Admin
Location
Room 237
No.
If your sure your set up for uefi then simply boot from the media windows is on.
Find the drive you want windows on and delete all partitions leaving an unallocted space.
Do not click anything else other than 'next' otherwise it will come out as mbr again.
Do not click format drive, just click next and you should find it will format it gpt automatically.
Windows Forum Admin
Location
Room 237
Look in your Bios for the heading 'Boot' or similar and then change the boot order so that your system boots from either the disk or usb you have windows on.
I should have also mentioned above that you want the 'Custom' install option followed by the drive you intend to install windows on. Delete all partitions and then click next. Job done.
Top Bottom
