Couple of questions before cloning W8
Winfried
Hello
I'd like to save an image of Windows 8 onto a second partition using Clonezilla, and have a couple of questions before proceeding:
1. Why does W8 create two partitions (350MB and 147.3GB) instead of just one?
2. When running fdisk in Linux, why does it display so many /dev/ramX partitions?
3. Using Clonezilla, should I save the two partitions so that restoring will work after trying another OS?
Thank you.
Here's the output of "fdisk -l" ran after booting live Linux from a USB keydrive:
# fdisk -l
Disk /dev/ram0: 64 MiB, 67108864 bytes, 131072 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram2: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram3: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram4: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram5: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram6: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram7: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram8: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/loop0: 1.4 GiB, 1536229376 bytes, 3000448 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sda: 3.7 GiB, 3926949888 bytes, 7669824 sectors
Disklabel type: dos
Disk identifier: 0x554126a2
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 7669823 7667776 3.7G c W95 FAT32 (LBA)
Disk /dev/sdb: 298.1 GiB, 320072933376 bytes, 625142448 sectors
Disklabel type: dos
Disk identifier: 0x000dde89
/dev/sdb1 * 2048 718847 716800 350M 7 HPFS/NTFS/exFAT
/dev/sdb2 718848 309694463 308975616 147.3G 7 HPFS/NTFS/exFAT
/dev/sdb3 309694464 561821695 252127232 120.2G 83 Linux
/dev/sdb4 617334858 625142447 7807590 3.7G 82 Linux swap / Solaris
Neemobeer
Application and Cloud Security Engineer
1. All Windows versions starting with Vista use 2 partitions, The small partition contains the boot manager and all relative boot information, the second partition being the operating system, programs and all your data
2. The /dev/ram# devices are just ram disks since clonezilla is booted as a "live disc" it lives in ram
3. Yes you will need to restore both
Winfried
Thanks for the info.
After posting, I read this elsewhere:
"The second 100mb partition is your boot sector, plus recovery options. You should NOT delete this; however, you can avoid the creation of this partition if you format your drive using something other than the Windows Setup before installing Windows. […] You can also avoid two partitions during setup by deleting the boot partition (the larger one) and then expanding the 100MB partition."
I'll do that next time, so as to keep everything in a single partition.
