totowindowx7
Hi I am the administrator of my system. I want to delete old repertories. But they have the attribute "only reading" and when I delete this attribute, it comes back
To delete old directories on your system that have the "Read-only" attribute set and prevent changes from persisting, follow these steps to remove the attribute permanently:
Via Command Prompt:​
  • Open Command Prompt as Administrator:
  • Type cmd in the Windows search bar.
  • Right-click Command Prompt and select "Run as administrator."
  • Navigate to the Folder:
  • Use the cd command to change the directory to the folder you want to modify.
    cmd cd path_to_folder
  • Remove Read-only Attribute:
  • Use the attrib command with -r to remove the read-only attribute from the folder and its subfolders.
    cmd attrib -r /s /d
Via File Explorer:​
    cmd attrib -r /s /d
Via File Explorer:​
  • Folder Properties:
  • Right-click on the folder, go to "Properties."
  • Uncheck the "Read-only" attribute in the General tab.
  • Apply changes to all files and subfolders.
  • Security Permissions:
  • Go to the Security tab in Properties.
  • Click "Edit" and ensure your user account has full control.
Additional Tips:​
  • Ownership Change:
  • If you encounter permission-related issues, take ownership of the folder before modifying attributes.
  • Command Line Actions:
  • Use appropriate commands in Command Prompt to change attributes, like icacls.
  • Administrator Rights:
  • Ensure you have administrative privileges during these operations. By utilizing these methods, you can adjust folder attributes effectively. If the read-only attribute persists due to permission issues, ensure that you have the necessary permissions and ownership of the directories you are attempting to modify.
