JosiahPittman23
Active Member
So the laptop I use has on keyboard volume up and down buttons, how would I disable the pop noise it makes when I increase or decrease the volume?
Hint hint. It's a MacBook in a dual boot
Sent from my iPhone using Tapatalk
It really depends on the device. You may not be able to disable it at all or it will be through the device driver or supporting utility.
BIGBEARJEDI
It could be the volume switches or the circuit inside of the MacBook keyboard. Have you tried plugging in an external keyboard that has volume controls on it, either USB or Firewire? If the volume controls on the external keyboard work, then your MacBook keyboard has failed and needs to be replaced.:waah:
This is what I'd suggest to fix this same problem on a Windows laptop as well.
Best,
<<<<BIGBEARJED>>>>
JosiahPittman23
Active Member
I haven't yet tried a external keyboard but I do have one and I'll try it when I get home later today.
I just wanted to know how to disable the default noise or sound it makes when I increase and/or decrease the volume from the buttons... kinda similar to the ding noise Windows makes when you move the volume sliders up or down but it makes a different but similar noise when I use the keyboard volume buttons as opposed to the volume slider on Windows. I know I can disable the ding noise inside Windows sound settings itself but I didn't know if I could disable the pop sound.
Neemobeer
Windows Forum Team
