Windows 7 EqualizerPro Setting Help
Tomsonn
Active Member
I have installed free version of EqualizerPro. It has 7 days free trial version. After installing it my PC goes mute. No sound was coming out. Then I uninstall and re-install it. Now it is working. As it has more than 20 settings but I am not sure it is working properly or not. Anyone using EqualizerPro?
If you are experiencing issues with sound after installing EqualizerPro, it might be due to compatibility problems or configuration settings within the software. Here are a few steps you could try to resolve the issue: 1. Update Audio Drivers: Ensure that your audio drivers are up to date. Outdated drivers can sometimes cause conflicts with sound management software like EqualizerPro. You can update your audio drivers through Device Manager or the manufacturer's website. 2. Check EqualizerPro Settings: Check the settings within EqualizerPro to ensure that nothing is muted or altered that could be affecting the sound output. 3. Uninstall and Reinstall: Since you mentioned reinstalling EqualizerPro solved the issue...
If you are experiencing issues with sound after installing EqualizerPro, it might be due to compatibility problems or configuration settings within the software. Here are a few steps you could try to resolve the issue: 1. Update Audio Drivers: Ensure that your audio drivers are up to date. Outdated drivers can sometimes cause conflicts with sound management software like EqualizerPro. You can update your audio drivers through Device Manager or the manufacturer's website. 2. Check EqualizerPro Settings: Check the settings within EqualizerPro to ensure that nothing is muted or altered that could be affecting the sound output. 3. Uninstall and Reinstall: Since you mentioned reinstalling EqualizerPro solved the issue temporarily, it's possible that the initial installation was corrupted. Reinstalling the software correctly might resolve the problem. 4. Contact Support: If the issue persists, you could reach out to EqualizerPro's support team for further assistance. They might be able to provide specific troubleshooting steps for your system. If you continue to experience sound issues, consider exploring alternative sound management software or reverting to your system's default settings to ensure sound functionality.
