- Thread Author
- #1
an eror message has been bugging my lately, rather since I started using programs which use the remote access connection manager.
one of them is songbird (the fire-foxy media player) which cannot listen to shared music, and SecondLife which uses it to make http calls, both of which make up pretty major parts of my day to day.
the actual error reads:
Network Connections
Cannot load the remote access connection manager service.
Error 711: the operation could not finish because it could not start the remote access connection manager service in time. please try the operation again.
I found Link Removed - Invalid URL which explains that windows is stupid and I should load the following dependant services manually.
Telephony
Remote Access Connection Manager
Remote Access Auto Connection Manager
Telephony on my computer is already running, the Remote Access Auto Connection Manager depends on Remote Access Connection Manager, when I try to start the Remote Access Connection Manager service I get the error message:
Services
Windows could not start the remote access connection manager service on local computer
Error 1068: The dependancy Service or group failed to start.
so, down the rabit hole....
the Remote Access Connection Manager depends on Telephony (already running) and Secure Socket Tunneling Protocol Service.
when I try to manually start the Secure Socket Tunneling Protocol Service I get the following informative message:
Services
The Secure Socket Tunneling Protocol Service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs.
this is the end of our journey I'm afraid, its a circular problem as apparently the rabit hole leads to a perfectly functional service. So I'm at a loss, and would very much like to hear a solution or from anyone with similar issues.
thanks for any advice.
Rabit
Network Connections
Telephony
Services
Services
Rabit
