Cyril Humbertclaude
Active Member
The images on my shortcuts are not displayed by taking the entire surface of my icon, while the image. ICO associated is big enough!
The display in Windows Explorer is set to "Large Icons".
Why ?
It seems like you are experiencing an issue where the images on your shortcuts are not displayed properly in Windows Explorer even though the associated .ICO file is big enough. This can be frustrating, but there are a few reasons why this might be happening: 1. Icon Size Limitation: Windows has limitations on the size of icons it displays for shortcuts. Even though the .ICO file itself may be larger, Windows may resize it to fit within its icon display constraints. 2. Resolution Compatibility: The resolution of the .ICO file may not be compatible with the display settings you have set in Windows Explorer. Windows may scale down icons that are of higher resolution to fit within the display. 3. Icon Cache: Sometimes...
It seems like you are experiencing an issue where the images on your shortcuts are not displayed properly in Windows Explorer even though the associated .ICO file is big enough. This can be frustrating, but there are a few reasons why this might be happening: 1. Icon Size Limitation: Windows has limitations on the size of icons it displays for shortcuts. Even though the .ICO file itself may be larger, Windows may resize it to fit within its icon display constraints. 2. Resolution Compatibility: The resolution of the .ICO file may not be compatible with the display settings you have set in Windows Explorer. Windows may scale down icons that are of higher resolution to fit within the display. 3. Icon Cache: Sometimes, the icon cache in Windows may be corrupted or have outdated information, leading to improper display of icons. Clearing the icon cache can sometimes resolve these issues. To address this issue, you can try the following steps: 1. Clear Icon Cache: Clearing the icon cache may help in refreshing the icons displayed for shortcuts. Here's how you can do it: - Press Win + R to open the "Run" dialog. - Type cmd and press Enter to open the Command Prompt. - In the Command Prompt, type the following commands one by one and press Enter after each:
 ie4uinit.exe -show taskkill /IM explorer.exe /F DEL "%localappdata%\IconCache.db" /A explorer.exe
- After running these commands, check if the issue persists. 2. Change Shortcut Icons: You can try changing the icons of the shortcuts to see if a different icon displays correctly. Right-click on the shortcut, go to "Properties," and then click on "Change Icon" to select a different icon. 3. Check Display Settings: Ensure that your display settings in Windows Explorer are set to "Large Icons" as you mentioned. This ensures that the icons are displayed in a larger size. By following these steps, you may be able to resolve the issue with the shortcut icons not displaying properly. If the issue persists, there may be other underlying factors causing the problem.
