ahmetsari New Member Joined Feb 11, 2019 Messages 3 Feb 11, 2019 Thread Author #1 there is no flicks tab . i have taken a screenshot, find the attachment Attachments Screenshot_1.webp 15.1 KB · Views: 236
Solution Neemobeer Feb 12, 2019 You can try the following Open 'Command Prompt' Run the following command reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t ' Reboot and test
Neemobeer Cloud Security Engineer Staff member Joined Jul 4, 2015 Messages 8,998 Feb 12, 2019 #2 You can try the following Open 'Command Prompt' Run the following command reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t ' Reboot and test Upvote 0 Downvote Solution
ahmetsari New Member Joined Feb 11, 2019 Messages 3 Feb 12, 2019 Thread Author #3 Thanks for your responding. But unfortunately having same result even though applied the command that you said Upvote 0 Downvote
ahmetsari New Member Joined Feb 11, 2019 Messages 3 Feb 12, 2019 Thread Author #4 by the way I have installed a pen tablet driver into my system Upvote 0 Downvote
blackmagicislam Well-Known Member Joined Jan 18, 2018 Messages 185 Feb 20, 2019 #5 Any other way Upvote 0 Downvote
