CoDeZ
Hello, i am new user here and i am posting this thread hoping that my issue can be solved.
Problem is, all old games on my HDD seem to lag like Captain Claw, Pocket Tanks, Yuri Revenge, Red Alert , Need For Speed UnderGround 1 all of them lag so high,after using fraps it seems that all games run with 1~5 FPS which is pretty annoying.
My Current PC Specs:
ASrock H61-M HVS
6 Gigs of ram
Asus GTX 550 ti
Core i3 2100 3.1Ghz 3 MB Cache.
Samsung LED 23" 1920*1080.
On Windows 7 all these games works perfectly, but when it comes to windows 8 it lags, any suggestions? :/
I notice in the log it states 'Warning: Unknown board ID D104 (It is recommended you obtain a new version of NVFLASH.)
Your using version 5.100. The latest version is now at 5.127 which you can download here:
Download NVFlash 5.127 | techPowerUp
I'm not sure if this is the solution to your issue but I guess it's worth a shot?
CoDeZ
Hello, thanks for replying, yes I do have all latest drivers
For my Motherboard I installed all drivers and installed the latest bios except the VGA driver since I am using an external VGA
for my VGA, I downloaded the latest driver from asus website, except the bios it doesn't flash
ASUS - Graphics Cards- ASUS ENGTX550 Ti DC/DI/1GD5
I downloaded the bios from there, and I am sure I didn't mistake the driver, but when I try to flash bios it sends the following error:
"Your graphic card of current system don't match this VBIOS"
Maybe this could be the problem?
CoDeZ
Hello, thanks for replying.
Yes I do have all the latest versions for my motherboard, even bios, except the VGA driver I didn't install it as I am using an external VGA (Asus GTX 550 Ti)
and yes I also have the latest driver for my external VGA card except BIOS driver.
When I try to flash bios, it says the following.
I got the drivers from here.
http://www.asus.com/Graphics_Cards/NVIDIA_Series/ENGTX550_Ti_DCDI1GD5/#download
And here is my log.
Maybe this might be causing the lag?
*** NVFLASH LOG FILE ***
Version 5.100
Command: version
FindDevices:
Device:00:00:00=8086:0100:1849:0100
Device:00:01:00=8086:0101:1849:0101
Device:00:16:00=8086:1C3A:1849:1C3A
Device:00:1A:00=8086:1C2D:1849:1C2D
Device:00:1B:00=8086:1C20:1849:0397
Device:00:1C:00=8086:1C10:1849:1C10
Device:00:1C:02=8086:1C14:1849:1C14
Device:00:1D:00=8086:1C26:1849:1C26
Device:00:1F:00=8086:1C5C:1849:1C5C
Device:00:1F:02=8086:1C00:1849:1C00
Device:01:00:00=10DE:1244:1043:83BC GPU
Device:01:00:01=10DE:0BEE:1043:83BC
Device:03:00:00=10EC:8136:1849:8136
Action: Display version.
Action: Identify EEPROM.
Atmel Serial EEPROM Identify.
Reported Manufacturer Code (JEDEC): C2
Reported Device Code (JEDEC): 2010
EEPROM ID (C2,2010) : MX MX25L512 2.7-3.6V 512Kx1S, page
Action: Read EEPROM image.
Reading EEPROM bytes.
Start: 0x00000000
Count: 65536
Read complete.
Image Size            : 61440 bytes
Version               : 70.26.20.00.00
~CRC32                : E7E2AE70
OEM String            : NVIDIA
Vendor Name           : NVIDIA Corporation
Product Name          : GF106B Board - 10500000
Product Revision      : Chip Rev
Device Name(s)        : GF1xx
Board ID              : D104
WARNING: Unknown Board ID D104
(It is recommended you obtain a newer version of NVFLASH.)
PCI ID                : 10DE-1244
Subsystem ID          : 1043-83BC
Hierarchy ID          : Normal Board
Chip SKU              : 400
Project               : 1050-0000
CDP                   : N/A
Build Date            : 02/16/11
Modification Date     : 05/19/11
Sign-On Message       : ENGTX550 Ti VB Ver 70.26.20.00.AS09
CoDeZ
When I tried to run this one, it said its incompatible for x64 bit windows version, after pressing okay, it returned to the old message
So I searched for the same version for x64 but couldn't find, searched for lower versions and I found 5.118 so downloaded, but still the same error.
and here is the log
Version 5.118
Command: version
FindDevices:
Start: 0x00000000
Count: 65536
Read complete.
~CRC32                : E7E2AE70
OEM String            : NVIDIA
Device Name(s)        : GeForce GTX 550 Ti
Board ID              : D104 (P1050 SKU 0)
PCI ID                : 10DE-1244
Chip SKU              : 400
Project               : 1050-0000
CDP                   : N/A
Coproc Build          : NO
