Tim Wardman
Hello all,
shortly put. I have a pc that is completely setup the way I want it to be. OS, updates, anti virus etc.
Can I copy this setup (known, I believe as a an "image") directly to a USB stick that becomes bootable in the process?
From here I can use that USB as the standard "image" for all my students. They have identical machines.
Any advice gratefully received and if you speak to me as you would a old family dog, that would be fine too
Thanks
Tm in Denmark
Best bet is to have two usb's. One with a bootable version of Macrium Reflect (free) and one with in image created under Macrium Reflect. You can then boot from the first one and use it, restore the image from the second one.
patcooke
Microsoft MVP
Microsoft MVP
