- Thread Author
- #1
Assume I have a running portable program on my Windows 10 system.
Its works.
Now I want to run it from USB flash drive on various computers without leaving traces.
At first the USB flash drive should boot a Windows 10 system from it.
Then afterwards automatically start the target program (in full screen) from it.
The Win 10 system installed on the USB Flash drive should contain only the minimum (Legacy BIOS/UEFI) stuff needed (particularly drivers).
Any unnecessary overhead should be automatically removed. So I guess WinPE is the right choice.
How can I achieve this?
Is there an easy-to-use tool which does everything with a minimum of clicks?
When I for example install Windows 10 the traditional way on an USB flash drive then a lot of useless Windows 10 stuff is installed (Start menu, Taskbar,...)
Furthermore no immediate auto-start of the actual program can be setup.
I need just the core Windows 10 (from ISO).
Any recommendations for this scenario?
Its works.
