Windows 10 How to print to dynamic IP printer
patrick chan
Member
I have a window 10 PC , it use wired network to connect internet , the IP address is 10.117.32.31
I have a router , the internet IP is 10.117.32.32 , I also have a printer attached this router , the printer dynamic IP is 192.168.1.110
Now If I want the above PC ( IP address : 10.117.32.31 ) can print to this printer , how to config it ?
thanks a lot .
ussnorway
Windows Forum Team
start by opening CMD from the main computer and ping the 192 address... assuming the router is not also a firewall that should get a reply
if you don't get a reply then the network will need work done before you can talk to the printer... make sure the printer is actually turned on
An image from 'How to print to dynamic IP printer'. A Windows Command Prompt shows successful ping replies from IP 192.168.1.1 with 0% packet loss.
patcooke
Microsoft MVP
Microsoft MVP
Why is the printer being given a dynamic address on a class C network 192.168.*.* and where is it being allocated from? Why not just used DHCP from the router to allocate a class A address on 10.*.*.*
bochane
I think I would allocate in the setup menu of the printer a static and fixed, not a dynamic and changing IP address.
