Windows 10 How to set priority at process/application start?
MIRKOSOFT
Active Member
Hello!
I need to start applications in any priority to avoid interferre their access.
How is possible to select priority (real-time, high, low etc.) for application or process start?
Thank you for all.
Miro
Add the shortcut to the start up or run location, then in task manager go to the start up tab and right click the process and set the priority
No this way - I need set it automatically - in Task Manager it is this way known and possible.
I need to set priority for some applications when I execute them without any changing later.
Miro
There is no way to set it automatically besides task manager or programmatically.
So, my hope is only to find any tool allowing it.
I'm sad 'cause this is very important feature and yet it was not created.
But thank you for help.
Miro
Improperly setting process priority will result in an unresponsive system. It isn't really meant to be messed with. Windows automatically adjusts priority when needed.
But I need to set priority and I'm not beginner when I'm writing it.
Miro
That's literally what I said, task manager or programmatically.
