Windows 7 I need help with an Error
Edoo1990
Does somebody now, how do i fix this issue? i cant run a game, i tried some tips, but nothing worked so far to solve the problem.
This might happen if it's an old game with an old DRM, like SecuROM. 64 bit Windows can't properly emulate that old code so you'd have to find a emulator (not sure if that will actually work anymore) or find a DRM-free crack. Before you try that though, have tried running in compatibility mode for an Older Windows version, like XP SP2, 2000, or 98?
Sent from my RS988 using Tapatalk
