xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #1
xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #3
No i didnt run a chkdsk. But it normally checks my disk on some startups so idk if thats actually it. I will try the command promt thing though. And i am doing a upgrade not a clean install.
Now drew im not sure how a malware would get on a file but i also dont think a system restore would work for it. And for the repair part i really dont know how to do that.
For both of you i have tried to upgrade twice and it did the same thing both times.
I will try one more time then try the suggestions if it fails.
xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #4
xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #6
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,186
xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #8
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,186
xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #10
Almost automatically, thirdparty software puts an item in the startup sequence. They are almost entirely uneeded. They remain installed, of course, and all can be started manually, on demand. As reghakr says, the only essential is the anti malware program, I am sure you will notive a significant improvemnt in your start up time and the use of resources, if you follow the advice.
reghakr
- Joined
- Jan 26, 2009
- Messages
- 14,186
jdownloader doesn't look that good,. especially since it';s starting from the c:\users path.
You simply don't need all that junk loading with Windows.
I would perform a "clean" install,. not an upgrade or your pron;ems will just carry over.
However, you will need to re-install all your 3rd party applications.
xgucciboix
- Joined
- Nov 30, 2009
- Messages
- 16
- Thread Author
- #13
Similar threads
- Solved
- Replies
- 1
- Views
- 378
- Replies
- 3
- Views
- 436
- Replies
- 2
- Views
- 1K
- Replies
- 6
- Views
- 3K
