Windows 7 I need some technical help with a wireless adapter
follower4Christ
Hello, I need some advice - I'm trying to fix this any ideas? thanks! ~
Looks more like a roblem with the modem/router than the wireless adapter. Is your pc showing as "connected" to the router?
Has the router previously worked but now stopped or is it a new one?
Go to programs, accessories, command prompt, run it and enter the following command:
ipconfig /all
SPost the output on here and we can help analyse the problem better.
ipconfig /all
Sometimes just unplugging the modem/router from the AC outlet for one minute and then plugging it back in will do the trick.
