amane
Hello All,
We are observing lots of ICMP traffic from a windows system. However, we are not able to identify which application is generating this traffic.
We tried to check by using "netstat -abn" however, it shows only TCP and UDP traffic, but not ICMP.
Is there any feature or utility in windows that can tell us which application is causing this?
Thanks in advance.
Ameer Mane
Sent from my Moto G (4) using Tapatalk
There's nothing I'm aware of that will give you this kind of information. I experimented with netsh trace and firewall audit logging. I think at best you will have to run procmon and look for calls to ping.exe and do a little research to ID dot net api calls to programmatically send out ICMP packets.
Neemobeer
Windows Forum Team
amane
Hello Neemobeer,
Thanks for update. I will look for procmon as I have not explored it yet. I will try it and will let you know.
Regards,
Ameer Mane
