DrChris
Hi all
I get IOMap64 BSOD when booting very often. I'm not too sure if these are related to hardware [i.e. overclocking] or a software [like USB drivers or ASUS software]. I went ahead and removed the ASUS AI III software just now just in case - but I would much appreciate if someone had any insight as to what is gone wrong.
Thank you and happy new year to all!
BugCheck 50, {ffffd5fee55001e4, 0, fffff80f0b981934, 2}
*** WARNING: Unable to verify timestamp for IOMap64.sys
*** ERROR: Module load completed but symbols could not be loaded for IOMap64.sys
Probably caused by : memory_corruption
Followup...
This could be an issue relating to bad memory, AV or file system corruption. I'd start by running memtest on your RAM then try disabling your AV if the 8 passes on the RAM are successful.
10: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffd5fee55001e4, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80f0b981934, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Followup:     memory_corruption
Bugcheck 50 can be caused by a number of issues namely, drivers, Hardware (usually RAM) and AV suites to name but a few.
You do have a driver appearing in the Stack which is almost a sure sign that's the culprit:
 nt!KeBugCheckEx
`string'+0x41fc4
nt!MmAccessFault+0x9ca
nt!KiPageFault+0x13c
IOMap64+0x1934
0x8
0xffff858b`000001c8
0xffff858b`d5ca29d0
0xffff858b`d91edad0
0xffff858b`d5ca2b20
IOMap64+0x163d
IOMap64.sys Thu Oct 23 01:52:12 2014: ASUS Kernel Mode Driver ?Asus Smart Doctor/iTracker 2 Asus GPU Tweak and GPU Tweak
Please remove to test.
If the bsod continues then follow Neem's advice and run Memtest86
Thank you both.
No Antivirus installed so that rules that out. Also, I did a completely fresh installation earlier this week to also eliminate file corruption as Nee suggested - so while it might be something relating to any of the software/drivers I have installed since, the chances are lower.
I have just now removed the ASUS software as suggested by kemical; and run windows' own memory diagnostic. According to MemoryDiagnostics-Results in Event Viewer: The Windows Memory Diagnostic tested the computer's memory and detected no errors.
But - I still have a suspicion that it could be the memory or perhaps the compatibility of the memory with my motherboard. Maybe an idea is to switch XMP profile off and apply the timings manually. In any case - I will run Memtest86 as suggested and report back.
Appreciate the help.
Chris
Kemical - once memtest86 completes - would you be able to take a look at results at all? [According to their instructions, the results generate a \EFI\BOOT\MemTest86.log file which I can attach if needed.]
Depending on what Memtest86 reports I'd leave the settings for now.
Agreed. I've just checked through CPUz and Bios XMP does accurately define timings correctly for all 4 modules. So I'll leave settings intact for now.
Sure no problem although if there are error's they are usually easy to spot.
Kemical/Neem - happy 2017 folks.
As a short update - 12 hours of memtest86 later [and through the change of the new year], the report came out clean [copied below as I'm not able to upload an .html file].
Summary
Report Date 2017-01-01 10:38:08
Generated by MemTest86 V7.2 Free (64-bit)
Result PASS
System Information
EFI Specifications 2.40
System
Manufacturer ASUS
Product Name All Series
Version System Version
Serial Number System Serial Number
BIOS
Vendor American Megatrends Inc.
Version 1401
Release Date 11/08/2016
Baseboard
Manufacturer ASUSTeK COMPUTER INC.
Product Name STRIX X99 GAMING
Version Rev 1.xx
Serial Number 160675391400897
CPU Type Intel Core i7-6850K @ 3.60GHz
CPU Clock 3600 MHz [Turbo: 3860.0 MHz]
# Logical Processors 12
L1 Cache 4 x 64K (198281 MB/s)
L2 Cache 4 x 256K (55285 MB/s)
L3 Cache 15360K (33187 MB/s)
Memory 33023M (16527 MB/s)
DIMM Slot #0 8GB DDR4 XMP PC4-27200
Corsair / CMU32GX4M4C3400C16
16-18-18-36 / 3400 MHz / 1.350V
DIMM Slot #1 8GB DDR4 XMP PC4-27200
DIMM Slot #2 8GB DDR4 XMP PC4-27200
DIMM Slot #3 8GB DDR4 XMP PC4-27200
Result summary
Test Start Time 2016-12-31 20:29:56
Elapsed Time 12:29:37
Memory Range Tested 0x0 - 840000000 (33792MB)
CPU Selection Mode Round Robin (All CPUs)
# Tests Passed 48/48 (100%)
Test # Tests Passed Errors
Test 0 [Address test, walking ones, 1 CPU] 4/4 (100%) 0
Test 1 [Address test, own address, 1 CPU] 4/4 (100%) 0
Test 2 [Address test, own address] 4/4 (100%) 0
Test 3 [Moving inversions, ones & zeroes] 4/4 (100%) 0
Test 4 [Moving inversions, 8-bit pattern] 4/4 (100%) 0
Test 5 [Moving inversions, random pattern] 4/4 (100%) 0
Test 6 [Block move, 64-byte blocks] 4/4 (100%) 0
Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
Test 8 [Random number sequence] 4/4 (100%) 0
Test 9 [Modulo 20, ones & zeros] 4/4 (100%) 0
Test 10 [Bit fade test, 2 patterns, 1 CPU] 4/4 (100%) 0
Test 13 [Hammer test] 4/4 (100%) 0
Certification
This document certifies that the Tests described above have been carried out by a suitably qualified technician on the System described above.
Which does make me wonder if indeed your initial suspicions that it could be ASUS AI Suite software related was the culprit. In any case, for now at least, since removing all traces of ASUS software, the computer seems smooth.
I'll monitor and advise if something else comes up. In meantime - thanks a lot to both of you :)
Chris
