Windows 7 Keyboard Problems
rahikumar
I have an Acer Aspire llaptop which iss just over a yyear old.
When I type on the keyboard, it produces multiple lettters from time to tiimee. See this text for which I have not edited as an example!
I can't find aa way to fix this. I have been into coontrol panel and adjusted the settings bbut to no avail.
Please can annyone help? I would be really grrateful.
_____________________
Link Removed - Invalid URL
Link Removed due to 404 Error
You might get a soft paint brush, and try to wisp it under keys. Maybe there is food or something stuck there.
Just wondering if you've inadvertently enabled Sticky Keys. Although I've never used the feature and am unsure how it actually works!! :D
