Looking for a solution to this problem
Hello all, I am currently looking for a way to make windows 7 always hide *.sfk, sfl, and .vf.bak files which sony vegas creates everytime you save a video file.
When you do a bunch of video editing and audio mixing it puts these files in the same folder as my renders
Its very annoying scrolling thru a long list of these files that sony vegas stores in my renders folder.
I want to know how I can make windows 7 always hide these files from my window.
-I normally don't enable show hidden files so this would be perfect
I just don't know how to make windows 7 hide specific file types with .sfk .sfl and .vf.bak extensions
Mitchell_A
Select all of those files, right click on them and select Properties, now under Attributes, select "Hidden" click OK.
Thanks, but I am looking for a way to make windows always hide these files without me needing to go thru and highlight them.
I remember reading a topic on it about a year ago which said reg edits control what file extensions windows can see by default.
Mitchell_A
Sorry, my mistake
I'll look around and see what I can find.
I would just move them all to the same folder and never open that folder.
Mitchell_A
Yes, and make that folder hidden.
#7
Can you change file locations in your software? Or, when you create a new file, can you specify where you save it to?
