Windows Terminal has transformed from a simple console window into an essential productivity powerhouse for developers, power users, and IT professionals alike. While its out-of-the-box experience is solid, the real magic of Windows Terminal lies in its extensive customization capabilities—turning a drab, default terminal into a tailored command center that’s as beautiful as it is functional.
A computer monitor displaying lines of colorful code or script on a dark background.Why Customizing Windows Terminal Matters​
Customizing your Windows Terminal does more than elevate its appearance. An optimized, aesthetically pleasing command line environment can significantly boost productivity, make repetitive tasks less tedious, and even help you visually segment different workflows. With growing support for integrations such as Visual Studio Code and Azure Cloud, a polished and personalized terminal is no longer just about style—it’s about efficiency and clarity.
The Evolution of Windows Terminal​
Microsoft’s shift in philosophy is evident in the evolution of Windows Terminal. Starting as a basic console in Windows 10, it has now become a flagship app in Windows 11, shipping pre-installed with a clean, modern interface and support for tabs, GPU acceleration, and rich customization. Major updates have focused on performance improvements and user experience, as confirmed by multiple independent sources, including the official Windows Terminal release notes and the Microsoft Developer Blog.
Getting Started: Installing Windows Terminal​
For Windows 11 users, Windows Terminal is already installed by default. Windows 10 users, or anyone running a lightweight build like Tiny 11, will need to install it manually:
  • Open the Start Menu, search for “Microsoft Store,” and launch it.
  • Search for “Windows Terminal.”
  • Click “Get” to begin installation.
This straightforward process ensures anyone on a modern Windows OS can access the latest version. Always be sure to use the Microsoft Store, as it provides official, regularly updated versions with all security patches.
The Core Customizations: Themes and Fonts​
Theme Overhauls Made Easy​
Out of the box, Windows Terminal offers a set of color schemes and a modern UI. But to truly personalize your workspace, leveraging third-party resources is essential.
Built-In Customization​
Accessing the terminal’s settings is easy:
  • Click the down arrow in the tab bar and select “Settings.”
  • Navigate to the “Appearance” tab.
  • Enable “Use acrylic material in the tab row” for transparency—this utilizes modern Windows visual effects (acrylic blur) for a refined look.
  • Explore pre-installed color schemes under the “Color Schemes” section. You can preview and set any scheme as the default, or add your own.
Creating Your Custom Color Scheme:
  • Click “Add new” in the color schemes section.
  • Edit colors for background, foreground, and cursor, assign a name, and save.
The Power of windowsterminalthemes.dev​
For a much wider, curated selection of themes, windowsterminalthemes.dev is a game-changer. Here’s how to use it:
  • Browse through hundreds of user-submitted color schemes.
  • Click “Get Theme” on a selection you like—this copies the JSON configuration to your clipboard.
  • In Windows Terminal settings, click the gear icon (“Open JSON file”) to edit the configuration directly.
  • Locate the “schemes” array, add a comma after the last entry, and paste your copied theme.
  • Save the JSON file, reload terminal settings, and apply the new theme from the color schemes menu.
This makes it easy to experiment with vibrant or minimalist palettes, whether you prefer a dark cyberpunk vibe or a white, distraction-free canvas.
Caution: Editing Settings Manually​
Directly editing the settings.json file is powerful but comes with risk. Typos or invalid JSON syntax can cause errors or prevent settings from loading. Always make a backup before making manual changes.
Fonts: Function Meets Beauty​
Fonts are not just about style—they impact readability and productivity. The default Windows Terminal font is clear and attractive, but power users often want more: ligatures, programming icons, or support for non-Latin scripts.
Introducing Nerd Fonts​
Nerd Fonts (nerdfonts.com) packages popular programming fonts, patched to include more than 3,600 icons for everything from development tools to OS logos. These are especially useful for powerline prompts, Git indicators, and visually rich CLI applications.
Installation Steps:
  • Download your chosen font zip from the Nerd Fonts releases on GitHub.
  • Extract the contents.
  • Select all font files, then right-click and choose “Install.”
  • In Windows Terminal, go to Settings > Defaults > Appearance, then select your installed Nerd Font under "Font face."
  • Hit “Save” to apply.
Choosing a Nerd Font such as “Cascadia Code Nerd Font” instantly brings icon support and a visually pleasing typeface—even for complex shell environments (like oh-my-posh or Starship prompts).
Beyond the Basics: Wallpaper and Transparency​
The visual overhaul doesn’t have to stop at themes and fonts. Windows Terminal lets you set custom background images, adding flair or helpful context cues.
To add a wallpaper:
  • Open Settings > Defaults > Appearance.
  • Under “Background image,” click “Browse” and select an image from your files.
  • Adjust “Background image opacity.” Around 20% keeps it subtle and legible.
  • Save changes to apply.
This feature can be used creatively—for example, assign different wallpapers to each shell profile to distinguish PowerShell from WSL or CMD at a glance.
Productivity Boost: Winget Integration​
No advanced terminal experience is complete without a package manager. Winget, Microsoft’s official package manager, brings Linux-like command-line convenience to Windows.
  • Windows 10 (latest builds) and all Windows 11 installations should have Winget by default.
  • To check, open a terminal and type winget.
  • If not found, install “App Installer” from the Microsoft Store, which adds Winget.
Now, you can use commands like winget install vscode, winget upgrade --all, or winget search <package> to manage software efficiently.
Pro-tip: Combine a customized prompt with Winget scripting for automated system setups—ideal for fresh installs or managing multiple environments.
Taking It Further: Custom Profiles, Shell Integration, and More​
Customization isn’t just about looks. Windows Terminal’s Model-View-Controller structure allows you to create dedicated profiles for each shell environment—PowerShell, Command Prompt, Azure Cloud Shell, WSL distributions, and any custom shells (like Git Bash or Zsh).
Profile Customization:
  • In Settings, add multiple profiles with different shells, each with its own theme and font.
  • Assign different icons or background images.
Experimenting with Shell Plugins:
  • PowerShell: Install oh-my-posh or posh-git for pretty, info-rich prompts.
  • Bash/WSL: Install Starship or Powerline for advanced prompts and Git status info.
  • Git Bash: Works out-of-the-box with Nerd Fonts, enhancing Git operations.
The Strengths of Windows Terminal Customization​
  • Flexibility: One app, any shell. Move seamlessly between projects without context switching.
  • Accessibility: Improved fonts and themes benefit users with visual needs.
  • Work Segmentation: Assigning unique visual cues for different environments reduces mistakes (e.g., running commands on the wrong server).
  • Productivity Gains: Visual clarity, powerful fonts, rapid software installs, and command automation accelerate complex workflows.
Potential Risks and How to Mitigate Them​
  • Over-customization: Excessive visual changes can distract or hinder usability. Keep functional clarity as a priority.
  • Manual JSON Edits: Editing settings.json improperly can corrupt profiles. Always back up before making major changes.
  • Font Compatibility: Not all fonts support the full range of Unicode or icons—some CLI tools may behave unpredictably with patched fonts. Stick to well-maintained Nerd Fonts for best results.
  • Performance: Using high-resolution wallpapers, transparency, or heavy image backgrounds may slightly impact performance on very old hardware, though it’s negligible on modern systems.
  • Third-Party Sources: Download themes and fonts only from reputable, well-reviewed sources. Both windowsterminalthemes.dev and nerdfonts.com are widely accepted and open-source.
Expert Tips for Master-Level Customization​
  • Automate setup: Save your settings.json file and font installs in scripts to reapply your environment on new machines.
  • Use settings fragments: In enterprise or multi-user environments, distribute reusable configuration fragments rather than full files.
  • Git integration: Use a prompt theme with real-time Git status and branch info—this reduces context-switching for developers.
  • Containerization: Combine Windows Terminal profiles with WSL2 or Docker containers for isolated, reproducible dev environments.
  • Accessibility: Test custom color schemes for accessibility, ensuring adequate contrast and legibility for all users.
FAQs: Expert Answers to Common Terminal Customization Questions​
Q: How do you make Windows Terminal look better?
Start by personalizing color schemes and fonts using built-in options or resources like windowsterminalthemes.dev and Nerd Fonts. Enable transparency and use a background image for extra flair—always ensure the result is readable and suited to your workflow.
Q: How do you install fonts in Windows Terminal?
Download and install fonts at the system level (right-click “Install”), then select your desired font in Terminal settings under Defaults > Appearance > Font face. Save and restart the terminal if needed.
Q: Is Windows Terminal better than CMD?
In almost every way. Windows Terminal is a modern, multi-tabbed terminal host that supports CMD, PowerShell, WSL, and custom shells, all within a single, customizable interface. CMD is just one shell you can access from within Terminal, making the latter far more versatile and powerful.
Q: Does customization affect functionality?
Visual customizations like themes and backgrounds mainly improve readability and user comfort. However, installing fonts like Nerd Fonts can unlock additional icons and prompt features directly in supported shells, blending aesthetics with enhanced functionality.
Conclusion: Level Up Your Command Line Experience​
Windows Terminal’s modern capabilities represent one of the biggest leaps in Microsoft’s developer-facing tools in years. Through targeted customizations—color schemes, fonts, backgrounds, and integrated tools like Winget—users can build a workspace that’s not only attractive but also finely tuned for productivity and efficiency.
Stick to reputable sources for themes and fonts, approach manual configuration with a cautious backup plan, and focus on your actual workflow needs. With a few well-chosen tweaks, your Windows Terminal can transform from a plain text box into a command-line cockpit worthy of a true pro.
The tools are in your hands—now it’s up to you to shape your ultimate Windows Terminal experience.
Source: TechPP How to Customize Windows Terminal Like a Pro - TechPP
