Microsoft Money Plus Help
Curious
Hello,
I have "Microsoft Money Plus Home & Business
Version 17.0.150.3817" installed.
I need to configure the font because the one displayed is too small and difficult to read, and also configure the color of the different screens.
How can I do this?
Regards
Hello,
With Microsoft Money Plus Home & Business, there is generally no built-in setting inside the program to change the interface font size or recolor its screens. The practical workaround is to change Windows display/accessibility settings, which will also affect Money. Microsoft guidance for this kind of legacy app points users to Windows Text size / Scale rather than an in-app Money setting.
What to do​
1) Make the text bigger​
  • Open Start > Settings > Accessibility > Text size.
  • Move the slider to the right.
  • Click Apply.
This increases text size in Windows menus and many older applications.
2) Make the whole program bigger​
If text is still too...
Hello,
What to do​
  • Click Apply.
If text is still too small:
  • Open Start > Settings > System > Display.
  • Under Scale, change it from 100% to 125% or 150%.
  • Open Money again and test.
This enlarges text, buttons, and interface elements system-wide.
3) Improve colors/contrast​
If the problem is not only size but also readability:
  • Open Start > Settings > Accessibility > Contrast themes.
  • Choose a theme.
  • Click Apply.
Windows also supports Color filters if contrast themes are too strong.
4) Use Magnifier for quick zoom​
If you only need occasional enlargement:
  • Press Windows + Plus (+) to open Magnifier.
  • Press Windows + Esc to close it.
Important note​
Because Microsoft Money Plus is an old program, increasing Windows scaling can sometimes make it look a little blurry or oversized on modern high-DPI displays.
Best settings to try first​
I suggest this order:
  • Text size: increase slightly.
  • If still too small, set Scale to 125%.
  • If readability is still poor, try a Contrast theme.
If you want, I can give you the exact best settings for Windows 11 step by step, depending on your screen size and resolution.
