Wisemanofhyrule
- Joined
- Sep 5, 2009
- Messages
- 2
- Thread Author
- #1
I cant install the RC since when I do it starts up and when I click install it says "Windows is missing a CD/DVD driver" then it gives me 2 options. Browse and Rescan. When I browse, the only driver I get is a kernel. Can you help?
Ps. Im trying to install the X64 version. My computer does support it.
rvwilliams
- Joined
- Oct 7, 2009
- Messages
- 8
I had the same problem. I re-burnt the DVD several times but each time the install failed in the same way. The way I solved it was to get a 4GB USB stick and follow the instructions on this page http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/. Fortunately the PC I was installing on had the USB boot option available and the install completed very quickly.
I hope this helps.
Richard Williams
I hope this helps.
Richard Williams
Similar threads
- Replies
- 4
- Views
- 2K
- Replies
- 9
- Views
- 5K
