Teufel
Hi, first post.
Just got Windows 7 RTM and installed it. First thing I noticed was the resolution. It was messed up. Big deal, I thought I'll just change it. I go to change it and the resolution is locked out at 800x600. I updated both the drivers for my monitor (Hannstar HF299) and my video card (Nvida 9600GT) and had no luck.
Are there any solutions, thanks in advance :)
Monitor info:
Monitor
Model name............... HF229
Manufacturer............. HannStar
Plug and Play ID......... HSD18B2
Serial number............ 821UHM03A3087
Manufacture date......... 2008, ISO week 21
EDID revision............ 1.3
Input signal type........ Digital (DVI)
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 480 x 300 mm (22.3 in)
Power management......... Active off/sleep
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Supported
MCCS revison............. 2.1
Display technology....... TFT
Controller............... Mstar 0x0
Firmware revision........ 1.0
Active power on time..... Not supported
Current frequency........ 16711.78kHz, 30.00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.649 - Ry 0.335
Green chromaticity....... Gx 0.283 - Gy 0.605
Blue chromaticity........ Bx 0.151 - By 0.073
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-82kHz
Vertical scan range...... 50-75Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1680x1050p at 60Hz (16:9)
Modeline............... "1680x1050" 146.250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1280 x 1024p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1440 x 900p at 75Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #4....... 1440x480i at 60Hz (16:9)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
CE video data (timings supported)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
640 x 480p at 60Hz - Default (4:3, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16-bit at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.1.0.0
Maximum TMDS clock....... 165MHz
Dxdiag:
System Information
Time of this report: 9/17/2009, 19:36:02
Machine name: DEEPTHOUGHT
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 4094MB RAM
Page File: 1007MB used, 7179MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
moar dxdaig
Display Devices
Card name: NVIDIA GeForce 9600 GT
Manufacturer: NVIDIA
Chip type: GeForce 9600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_054510DE&REV_A1
Display Memory: 2288 MB
Dedicated Memory: 497 MB
Shared Memory: 1791 MB
Current Mode: 800 x 600 (16 bit) (30Hz)
Monitor Name: Hannstar HF229
Monitor Model: HF229
Monitor Id: HSD18B2
Native Mode: 1680 x 1050(p) (59.954Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 8.16.0011.9062 (English)
Driver Version: 8.16.11.9062
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/17/2009 01:57:00, 9380352 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4562-11CF-0850-4E251EC2C535}
Vendor ID: 0x10DE
Device ID: 0x0622
SubSys ID: 0x054510DE
Revision ID: 0x00A1
Driver Strong Name: oem2.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section003:8.16.11.9062:pci\ven_10de&dev_0622
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Headphones (High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_198B&SUBSYS_1043829C&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: Yes
Date and Size: 7/13/2009 18:07:00, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (S/PDIF) (High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: Line In (High Definition Audio Device)
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC049
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/13/2009 18:07:09, 343040 bytes
| Driver: usbd.sys, 7/13/2009 18:06:23, 7936 byte
System Devices
Name: Broadcom 802.11g Network Adapter
Device ID: PCI\VEN_14E4&DEV_4318&SUBSYS_700114E4&REV_02\4&36AC3632&0&3078
Driver: C:\Windows\system32\DRIVERS\BCMWL664.SYS, 4.176.0075.0023 (English), 5/4/2009 23:24:56, 1316496 bytes
Driver: C:\Windows\system32\drivers\vwifibus.sys, 6.01.7600.16385 (English), 7/13/2009 18:07:21, 24576 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_0810&SUBSYS_00000000&REV_A1\3&2411E6FE&1&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0809&SUBSYS_00000000&REV_A1\3&2411E6FE&1&02
Driver: n/a
Name: NVIDIA nForce Networking Controller #2
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_CB841043&REV_A3\3&2411E6FE&1&90
Driver: n/a
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_CB841043&REV_A3\3&2411E6FE&1&51
Driver: n/a
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&36AC3632&0&5878
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 18:07:13, 227840 bytes
Device ID: PCI\VEN_10DE&DEV_080F&SUBSYS_00000000&REV_A1\3&2411E6FE&1&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0808&SUBSYS_00000000&REV_A1\3&2411E6FE&1&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_CB841043&REV_A3\3&2411E6FE&1&88
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_CB841043&REV_A3\3&2411E6FE&1&50
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 19:48:27, 15424 bytes
Device ID: PCI\VEN_10DE&DEV_081A&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_080E&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0F
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_0800&SUBSYS_00000000&REV_B1\3&2411E6FE&1&00
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_037110DE&REV_A2\3&2411E6FE&1&79
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 18:06:13, 122368 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_0815&SUBSYS_000010DE&REV_A1\3&2411E6FE&1&10
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 19:45:45, 183872 bytes
Device ID: PCI\VEN_10DE&DEV_080E&SUBSYS_00000000&REV_A1\3&2411E6FE&1&07
Driver: n/a
Name: NVIDIA GeForce 9600 GT
Device ID: PCI\VEN_10DE&DEV_0622&SUBSYS_054510DE&REV_A1\4&CC23A24&0&0010
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_0f2041334e2127ce\NvCplSetupEng.exe, 14.00.0000.0162 (English), 8/17/2009 01:57:00, 19517581 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.16.0011.9062 (English), 8/17/2009 01:57:00, 11168 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.16.0011.9062 (English), 8/17/2009 01:57:00, 11313312 bytes
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
