Windows 7 Most of my programs need to be in windows 7 compatibility mode to be able to be run. Help!
JericRyann
Prior to installing the updates using windows update, i can run my programs fine. But now after the updates, certain programs won't run unless I check compatibility mode windows 7 ex. steam, fraps,etc... how do i fix this?
Just to be certain......
1. Are you using IE11 or IE10.
If IE11, how long ago ?
2. Go to Windows Updates, click View Updates history, is IE11 installed recently ?
ah just fixed it. Updated my graphic's AMD drivers. Don't seem to know how that connects with the issue, but it works. Thanks for the help anyways though
davidhk129
,.................Prior to installing the updates.............
Is one of those updates an upgrade to Internet Explorer 11 for Windows 7 ?
davidhk129
JericRyann
I'm using chrome. and IE11 was installed 9 months ago. 1/4/2014
JericRyann
Pauli
Fantastic Member
Great you got it fixed - and you're not the first one to not understand the connections. "IT works in mysterious ways".
