Nimit
Honorable Member
Hey guys so when i start something like file explorer or navigate something in the browser the mouse start its loading icon right? so here is my issue after the loading it keep flicker then stop after some minutes.
The mouse cursor flickering issue can be quite frustrating and might be indicative of underlying system problems. Here are some steps you can take to address this problem:
1. Update Mouse Drivers:​
  • Ensure that your mouse drivers are up to date. Go to the Device Manager and right-click on your mouse device to update the drivers.
    2. Check for Hardware Issues:​
  • Try using a different mouse to see if the problem persists. If another mouse doesn't flicker, it might be a hardware issue with your current mouse.
    3. Perform a Clean Boot:​
  • Perform a clean boot to determine if the flickering is due to a third-party application or service. This will help identify any conflicting software causing the...
  • Perform a clean boot to determine if the flickering is due to a third-party application or service. This will help identify any conflicting software causing the flickering.
    4. Check for Background Processes:​
  • Monitor Task Manager to see if any particular process is consuming excessive resources when the mouse cursor flickers.
    5. Run System File Checker:​
  • Open Command Prompt as an administrator and run the System File Checker using the sfc /scannow command. This will check for and repair any corrupted system files.
    6. Update Graphics Drivers:​
  • Ensure your graphics drivers are up to date. Outdated or corrupt graphics drivers can sometimes cause cursor flickering issues.
    7. Check for Malware:​
  • Perform a full system scan with your antivirus software to rule out malware or hidden threats causing the issue.
    8. Adjust Visual Effects:​
  • Go to System Properties > Advanced System Settings > Performance > Settings and adjust visual effects to see if it affects cursor flickering.
    9. Disable Visual Effects:​
  • Temporarily disable any fancy visual effects such as mouse shadows or cursor animation to see if they are causing the flickering.
    10. Additional Troubleshooting:​
  • If the issue persists, run the Windows in Safe Mode to see if the issue is related to third-party software. You can also consider a system restore to a point before the flickering started. Addressing cursor flickering involves a process of elimination and testing different settings and software configurations to pinpoint the root cause. If the issue remains unresolved, consider reaching out to your system administrator or a tech support professional for further assistance.
