bugmenot123
Banned
- Joined
- Nov 2, 2008
- Messages
- 60
- Thread Author
- #1
Need a bit of help here. I've been trying everything I could think of for the past 3 days but nothing is working out for me.
I'm trying to set up W7 on my laptop, which already has Vista installed as the primary OS, and Ubuntu as a second OS. I was hoping the set up W7 as my third, but I've been having a lot of problems.
Let me just walk through what I've done so far. I downloaded W7 from the official site, but it stopped at 99%. So, I paused/resumed it, and then it went up to 100%. This just seemed like a glitch or something at first, but it came back a few times later. I burnt it to a DVD, and everything worked out fine there.
I then tried to set up another partition for W7. I first tried Vista's built-in partition software, and I was able to shrink the disk size, but when I tried to create a new Simple Volume, it said that I couldn't because the HDD already had the maximum amount of that type of partition (I assume it meant Primary?). So then I used EASEUS Partition Software, and was able to shrink the disk and create a new partion, but it automatically was assigned as a Logical partition. I remember reading somewhere that it had to be Primary, so this could be my problem.
Anyway, I rebooted and started to install W7. The install started up without a problem, and I was able to get everything started. I selected the partition I had assigned earlier, and it started to install, but then it said that some of the install files were missing. I assume that has something to do with the original download having problems.
So, I tried downloading the file a second time. Again, it stopped at 99%. It wouldn't let me pause/resume, though, so I exited and restarted the download manager, and then it immediately snapped up to 100%. Obviously, when I tried to boot it, it didn't work.
So, I downloaded it a third time. This time, the download went perfectly. So, I figured I wouldn't have any problems. Wrong, of course. This time, when I tried to boot it, it would do the whole "loading files" thing at the beginning, but then it would give me a setup screen, saying that the NLS data was missing or corrupted. Now, does this mean that my disk is bad again?
If my disk is bad, what am I doing wrong? I'm downloading from the official site and everything...
If it's not my disk, then what's the problem? I really don't know where to look, since it could be one of many different things (partition setup, for example).
I'm pretty good with computers, but I don't see how I could get a bad download 3 times in a row...
Any help would be greatly appreciated!
freddy1408
- Joined
- Jan 11, 2009
- Messages
- 32
bugmenot123
Banned
- Joined
- Nov 2, 2008
- Messages
- 60
- Thread Author
- #3
bugmenot123
Banned
- Joined
- Nov 2, 2008
- Messages
- 60
- Thread Author
- #5
Similar threads
- Replies
- 8
- Views
- 3K
- Solved
- Replies
- 1
- Views
- 4K
- Replies
- 1
- Views
- 1K
- Solved
- Replies
- 1
- Views
- 2K
- Replies
- 11
- Views
- 28K
