Windows 10 Multiple desktops in a multi-monitor setup
JosephDoe
I'm new to windows, so I'm sorry if this is a dumb question. I'm using Windows 10 after 15+ years using mac and Linux (switched from XP), and considering adopting Windows as my main OS.
I'm trying to use win+ctrl+arrow to change between desktops, with a multi monitor setup.
The problem is that when I switch desktops in one monitor, the other one changes too.
for example:
I have application 1 on display A.
And I have application 2 and 3 on display B, they are in desktops B1 and B2.
When I try to change from B1 to B2, Display A also also changes from A1(which I am using for aplication 1) to A2(which I do not need).
This makes impossible to work on application 1 while monitoring both applications 2 and 3.
I'm sure there is a box somewhere that I just need to tick, but I cannot find it anywhere.
