Windows 7 Need BSOD Help
psills
Asus Laptop - G1Sn
BSODs on a frequent basis (once/twice a day) no pattern
Have run Memtest 86 (no problem)
Have run Virus Scans (no problems)
Deleted all unneeded applications
Please Help!
Additional information follows in Zipped Files:
I hope this all helps!
I am at my wits END!!!
Thank YOU ALL VERY MUCH!!!
Update them:
Intel Wireless WiFi Link Driver
netw5v64.sys Thu Mar 26 12:21:24 2009
ASUS ATK Hotkey ATK0101 ACPI UTILITY Driver
ATK64AMD.sys Fri Oct 27 08:45:25 2006
NVIDIA
nvlddmkm.sys Fri Nov 20 22:40:46 2009
Drivers - Download NVIDIA Drivers
Ricoh Memory Card Reader driver
Home | Ricoh Global
Realtek LAN
Rt64win7.sys Wed Jun 23 05:10:45 2010
Realtek Audio
RTKVHD64.sys Thu Feb 14 04:03:02 2008
Suyin USB 2.0 Webcam driver
sncduvc.SYS Wed May 09 03:17:09 2007
Crash Dumps:
Microsoft (R) Windows Debugger Version 6.12.0002.633...
Update them:
NVIDIA
Home | Ricoh Global
Realtek LAN
Realtek Audio
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\030411-38594-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850
Machine Name:
Kernel base = 0xfffff800`03055000 PsLoadedModuleList = 0xfffff800`0329ae90
Debug session time: Fri Mar  4 15:04:09.306 2011 (UTC - 5:00)
System Uptime: 2 days 18:13:58.132
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {fffffb4003028f9a, 2, 0, fffff8000310b97f}
Unable to load image \SystemRoot\system32\DRIVERS\netw5v64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for netw5v64.sys
*** ERROR: Module load completed but symbols could not be loaded for netw5v64.sys
Probably caused by : netw5v64.sys ( netw5v64+10411 )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffb4003028f9a, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff8000310b97f, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800033060e8
 fffffb4003028f9a
CURRENT_IRQL:  2
FAULTING_IP:
nt!MiMapPageInHyperSpaceWorker+1b
fffff800`0310b97f 458a481a        mov     r9b,byte ptr [r8+1Ah]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  fffff800045ecc70 -- (.trap 0xfffff800045ecc70)
rax=0000058000000000 rbx=0000000000000000 rcx=0000000400100da8
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8000310b97f rsp=fffff800045ece08 rbp=0000000000000001
 r8=fffffb4003028f80  r9=0000000000000000 r10=0000000000000002
r11=fffff800045ecef0 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe cy
nt!MiMapPageInHyperSpaceWorker+0x1b:
fffff800`0310b97f 458a481a        mov     r9b,byte ptr [r8+1Ah] ds:fffffb40`03028f9a=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030d4be9 to fffff800030d5640
STACK_TEXT:
fffff800`045ecb28 fffff800`030d4be9 : 00000000`0000000a fffffb40`03028f9a 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff800`045ecb30 fffff800`030d3860 : fffffa80`06e7ddc0 fffff880`0175fd1e 00000000`00000000 fffffa80`01329f30 : nt!KiBugCheckDispatch+0x69
fffff800`045ecc70 fffff800`0310b97f : fffff800`030bdf3b fffffa80`01329cf0 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260
fffff800`045ece08 fffff800`030bdf3b : fffffa80`01329cf0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiMapPageInHyperSpaceWorker+0x1b
fffff800`045ece10 fffff800`03122e69 : 00000000`00000002 fffff880`00000001 fffffa80`01329f30 00000000`00000001 : nt!MiRestoreTransitionPte+0x7b
fffff800`045ecea0 fffff800`031fe20a : 2aaaaaaa`aaaaaaab 2aaaaaaa`aaaaaaab fffff800`045ecf80 fffffa80`03c01c00 : nt!MiRemoveLowestPriorityStandbyPage+0x1d5
fffff800`045ecf20 fffff800`030f61d0 : 00000000`00100000 fffff800`0325c6c0 00000000`00000000 fffffa80`00000000 : nt!MiAllocatePoolPages+0xb8a
fffff800`045ed060 fffff800`0320090e : 00000000`00000000 fffff800`00000000 fffffa80`00000000 00000000`00100000 : nt!ExpAllocateBigPool+0xb0
fffff800`045ed150 fffff880`016e01bc : 00000000`00000000 fffffa80`0c7b5328 fffff800`045ed498 00000000`00da7a01 : nt!ExAllocatePoolWithTag+0x82e
fffff800`045ed240 fffff880`04ad0411 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ndis!NdisAllocateMemoryWithTag+0x1c
fffff800`045ed270 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`0009769c : netw5v64+0x10411
STACK_COMMAND:  kb
FOLLOWUP_IP:
netw5v64+10411
fffff880`04ad0411 ??              ???
SYMBOL_STACK_INDEX:  a
SYMBOL_NAME:  netw5v64+10411
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: netw5v64
IMAGE_NAME:  netw5v64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  49cbab84
FAILURE_BUCKET_ID:  X64_0xA_netw5v64+10411
Loading Dump File [F:\a\Minidump\D M P\DMP\030411-33649-01.dmp]
Machine Name:
Kernel base = 0xfffff800`0305f000 PsLoadedModuleList = 0xfffff800`032a4e90
Debug session time: Fri Mar  4 16:13:18.566 2011 (UTC - 5:00)
System Uptime: 0 days 1:08:39.392
BugCheck A, {fffffb4001daddba, 2, 0, fffff8000311597f}
Probably caused by : memory_corruption ( nt!MiMapPageInHyperSpaceWorker+1b )
0: kd> !analyze -v
Arguments:
Arg1: fffffb4001daddba, memory referenced
Arg4: fffff8000311597f, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800033100e8
 fffffb4001daddba
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`0311597f 458a481a        mov     r9b,byte ptr [r8+1Ah]
BUGCHECK_STR:  0xA
PROCESS_NAME:  MsMpEng.exe
TRAP_FRAME:  fffff88005d42810 -- (.trap 0xfffff88005d42810)
rax=0000058000000000 rbx=0000000000000000 rcx=000000040009e49e
rip=fffff8000311597f rsp=fffff88005d429a8 rbp=0000000000000001
 r8=fffffb4001dadda0  r9=0000000000000000 r10=0000000000000002
r11=fffff88005d42a90 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po cy
fffff800`0311597f 458a481a        mov     r9b,byte ptr [r8+1Ah] ds:8000:fffffb40`01daddba=??
LAST_CONTROL_TRANSFER:  from fffff800030debe9 to fffff800030df640
STACK_TEXT:
fffff880`05d426c8 fffff800`030debe9 : 00000000`0000000a fffffb40`01daddba 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`05d426d0 fffff800`030dd860 : 00000000`00000000 00000000`00000000 00000000`00000001 fffffa80`03621f30 : nt!KiBugCheckDispatch+0x69
fffff880`05d42810 fffff800`0311597f : fffff800`030c7f3b fffffa80`03621f00 00000000`00000001 00000000`00000000 : nt!KiPageFault+0x260
fffff880`05d429a8 fffff800`030c7f3b : fffffa80`03621f00 00000000`00000001 00000000`00000000 00000000`00000080 : nt!MiMapPageInHyperSpaceWorker+0x1b
fffff880`05d429b0 fffff800`0312ce69 : 00000000`0000b9bf 0000b9be`00000001 fffffa80`03621f30 00000000`00120b50 : nt!MiRestoreTransitionPte+0x7b
fffff880`05d42a40 fffff800`030ee004 : 00000000`00000000 00000000`00000000 fffff880`05d42b40 00000000`00000000 : nt!MiRemoveLowestPriorityStandbyPage+0x1d5
fffff880`05d42ac0 fffff800`030dd76e : 00000000`00000001 00000000`047350b8 00000000`00000001 00000000`047350b8 : nt!MmAccessFault+0x19e4
fffff880`05d42c20 00000000`7343ab2a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`0258e6c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7343ab2a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiMapPageInHyperSpaceWorker+1b
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7951a
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xA_nt!MiMapPageInHyperSpaceWorker+1b
Drivers:
fffff880`04fa0000 fffff880`04fde000   1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00f82000 fffff880`00fd9000   ACPI     ACPI.sys     Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`03e5d000 fffff880`03ee6000   afd      afd.sys      Sat Nov 20 04:23:27 2010 (4CE7938F)
fffff880`0ffce000 fffff880`0ffe4000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`01200000 fffff880`0120b000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`0a1dd000 fffff880`0a1e8000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`013ba000 fffff880`013c3000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`013c3000 fffff880`013ed000   ataport  ataport.SYS  Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`0441c000 fffff880`04424000   ATK64AMD ATK64AMD.sys Fri Oct 27 08:45:25 2006 (4541FF65)
fffff880`00db2000 fffff880`00dbe000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`02e3a000 fffff880`02e41000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0434e000 fffff880`0435f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03fcc000 fffff880`03fea000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006c0000 fffff960`006e7000   cdd      cdd.dll      unavailable (00000000)
fffff880`02fc9000 fffff880`02ff3000   cdrom    cdrom.sys    Sat Nov 20 04:19:20 2010 (4CE79298)
fffff880`00ec2000 fffff880`00f82000   CI       CI.dll       Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`01800000 fffff880`01830000   CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00d0c000 fffff880`00d6a000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04a59000 fffff880`04a5d500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`0116d000 fffff880`011df000   cng      cng.sys      Sat Nov 20 05:08:45 2010 (4CE79E2D)
fffff880`00eb3000 fffff880`00ebc000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`0ffbe000 fffff880`0ffce000   CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`089aa000 fffff880`089b8000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`042ad000 fffff880`04330000   csc      csc.sys      Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`04330000 fffff880`0434e000   dfsc     dfsc.sys     Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`03fbd000 fffff880`03fcc000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01bdb000 fffff880`01bf1000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0878a000 fffff880`087ac000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`089b8000 fffff880`089cb000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`052e4000 fffff880`05400000   dump_iaStor dump_iaStor.sys Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`08a27000 fffff880`08a33000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`04429000 fffff880`0451d000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 04:50:50 2010 (4CE799FA)
fffff880`0451d000 fffff880`04563000   dxgmms1  dxgmms1.sys  Sat Nov 20 04:49:53 2010 (4CE799C1)
fffff880`0a19d000 fffff880`0a1d3000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01257000 fffff880`0126b000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0120b000 fffff880`01257000   fltmgr   fltmgr.sys   Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0142c000 fffff880`01436000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01ba1000 fffff880`01bdb000   fvevol   fvevol.sys   Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`01a9e000 fffff880`01ae8000   fwpkclnt fwpkclnt.sys Sat Nov 20 04:21:37 2010 (4CE79321)
fffff880`0440f000 fffff880`0441c000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`03016000 fffff800`0305f000   hal      hal.dll      Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`045d7000 fffff880`045fb000   HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`08988000 fffff880`089a1000   HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`089a1000 fffff880`089a9080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0897a000 fffff880`08988000   hidusb   hidusb.sys   Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`02e96000 fffff880`02f5f000   HTTP     HTTP.sys     Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`01b98000 fffff880`01ba1000   hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`04a2c000 fffff880`04a4a000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010a5000 fffff880`0110f000   iaNvStor iaNvStor.sys Wed Jul 01 20:55:18 2009 (4A4C0576)
fffff880`0129e000 fffff880`013ba000   iaStor   iaStor.sys   Thu Jun 04 21:53:40 2009 (4A287AA4)
fffff880`00c5c000 fffff880`00c64000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0438e000 fffff880`043a4000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04a4a000 fffff880`04a59000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00b97000 fffff800`00ba1000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04256000 fffff880`04299000   ks       ks.sys       Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`01400000 fffff880`0141b000   ksecdd   ksecdd.sys   Sat Nov 20 04:21:15 2010 (4CE7930B)
fffff880`01788000 fffff880`017b3000   ksecpkg  ksecpkg.sys  Sat Nov 20 05:10:34 2010 (4CE79E9A)
fffff880`087ac000 fffff880`087b1200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`087d3000 fffff880`087e8000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`089d9000 fffff880`089fc000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00ca9000 fffff880`00cf8000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 08:03:51 2010 (4CE7C737)
fffff880`0893f000 fffff880`0894e000   modem    modem.sys    Mon Jul 13 20:10:48 2009 (4A5BCD08)
fffff880`0894e000 fffff880`0895b000   MODEMCSA MODEMCSA.sys Mon Jul 13 20:10:49 2009 (4A5BCD09)
fffff880`089cb000 fffff880`089d9000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04400000 fffff880`0440f000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`08a1a000 fffff880`08a27000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c74000 fffff880`00c8e000   mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`02e00000 fffff880`02e31000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`03fea000 fffff880`03ffa000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`02f5f000 fffff880`02f77000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02f77000 fffff880`02fa4000   mrxsmb   mrxsmb.sys   Sat Nov 20 04:27:41 2010 (4CE7948D)
fffff880`017b3000 fffff880`01800000   mrxsmb10 mrxsmb10.sys Sat Nov 20 04:26:53 2010 (4CE7945D)
fffff880`02fa4000 fffff880`02fc8000   mrxsmb20 mrxsmb20.sys Sat Nov 20 04:26:47 2010 (4CE79457)
fffff880`013ed000 fffff880`013f8000   msahci   msahci.sys   Sat Nov 20 05:33:58 2010 (4CE7A416)
fffff880`0183e000 fffff880`01849000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fe2000 fffff880`00fec000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0110f000 fffff880`0116d000   msrpc    msrpc.sys    Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`03fb2000 fffff880`03fbd000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01b86000 fffff880`01b98000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01635000 fffff880`01728000   ndis     ndis.sys     Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`0ffe4000 fffff880`0fff0000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`087e8000 fffff880`087fb000   ndisuio  ndisuio.sys  Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`043c8000 fffff880`043f7000   ndiswan  ndiswan.sys  Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`052cf000 fffff880`052e4000   NDProxy  NDProxy.SYS  Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`03f5a000 fffff880`03f69000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03ee6000 fffff880`03f2b000   netbt    netbt.sys    Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`01728000 fffff880`01788000   NETIO    NETIO.SYS    Sat Nov 20 04:23:13 2010 (4CE79381)
fffff880`04a65000 fffff880`04fa0000   netw5v64 netw5v64.sys Thu Mar 26 12:21:24 2009 (49CBAB84)
fffff880`0a107000 fffff880`0a11c000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`01849000 fffff880`0185a000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03e51000 fffff880`03e5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`0305f000 fffff800`03649000   nt       ntkrnlmp.exe Sat Nov 20 04:30:02 2010 (4CE7951A)
fffff880`01457000 fffff880`015fa000   Ntfs     Ntfs.sys     Sat Nov 20 04:20:57 2010 (4CE792F9)
fffff880`02e31000 fffff880`02e3a000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0ff66000 fffff880`0ff67180   nvBridge nvBridge.kmd Fri Nov 20 22:09:47 2009 (4B0759FB)
fffff880`0f258000 fffff880`0ff65a00   nvlddmkm nvlddmkm.sys Fri Nov 20 22:40:46 2009 (4B07613E)
fffff880`05200000 fffff880`05253000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03f34000 fffff880`03f5a000   pacer    pacer.sys    Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00d9d000 fffff880`00db2000   partmgr  partmgr.sys  Sat Nov 20 04:20:00 2010 (4CE792C0)
fffff880`00d6a000 fffff880`00d9d000   pci      pci.sys      Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00c64000 fffff880`00c74000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0141b000 fffff880`0142c000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`064ef000 fffff880`06595000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0874d000 fffff880`0878a000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cf8000 fffff880`00d0c000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`043a4000 fffff880`043c8000   rasl2tp  rasl2tp.sys  Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`04200000 fffff880`0421b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0421b000 fffff880`0423c000   raspptp  raspptp.sys  Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`0423c000 fffff880`04256000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e00000 fffff880`03e51000   rdbss    rdbss.sys    Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`0fff0000 fffff880`0fffb000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02e84000 fffff880`02e8d000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`04385000 fffff880`0438e000   rdpdispm rdpdispm.sys Thu Aug 19 19:20:11 2010 (4C6DBC2B)
fffff880`0a11c000 fffff880`0a14a000   rdpdr    rdpdr.sys    Sat Nov 20 06:06:41 2010 (4CE7ABC1)
fffff880`02e8d000 fffff880`02e96000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02ff3000 fffff880`02ffc000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0a164000 fffff880`0a19d000   RDPWD    RDPWD.SYS    Sat Nov 20 06:04:37 2010 (4CE7AB45)
fffff880`01b4c000 fffff880`01b86000   rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`04a00000 fffff880`04a15000   rimmpx64 rimmpx64.sys Wed Aug 08 04:39:44 2007 (46B98150)
fffff880`04a15000 fffff880`04a2c000   rimspx64 rimspx64.sys Thu Jul 26 07:33:52 2007 (46A886A0)
fffff880`0f200000 fffff880`0f257000   rixdpx64 rixdpx64.sys Fri Jul 27 06:45:50 2007 (46A9CCDE)
fffff880`05253000 fffff880`0526b000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0ff68000 fffff880`0ffbe000   Rt64win7 Rt64win7.sys Wed Jun 23 05:10:45 2010 (4C21CF95)
fffff880`08602000 fffff880`0874c800   RTKVHD64 RTKVHD64.sys Thu Feb 14 04:03:02 2008 (47B403C6)
fffff880`03f98000 fffff880`03fb2000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`04fde000 fffff880`04ffe000   sdbus    sdbus.sys    Sat Nov 20 04:37:42 2010 (4CE796E6)
fffff880`06595000 fffff880`065a0000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0880b000 fffff880`0893f000   smserial smserial.sys Mon Oct 26 11:36:18 2009 (4AE5C1F2)
fffff880`08a11000 fffff880`08a19980   sncduvc  sncduvc.SYS  Wed May 09 03:17:09 2007 (46417575)
fffff880`08a36000 fffff880`08bf4c00   snp2uvc  snp2uvc.sys  Mon Oct 01 02:59:45 2007 (47009AE1)
fffff880`01b44000 fffff880`01b4c000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0a06e000 fffff880`0a107000   srv      srv.sys      Sat Nov 20 04:28:05 2010 (4CE794A5)
fffff880`06400000 fffff880`0646b000   srv2     srv2.sys     Sat Nov 20 04:27:43 2010 (4CE7948F)
fffff880`065a0000 fffff880`065d1000   srvnet   srvnet.sys   Sat Nov 20 04:27:20 2010 (4CE79478)
fffff880`08a00000 fffff880`08a10d00   STREAM   STREAM.SYS   Mon Jul 13 20:06:18 2009 (4A5BCBFA)
fffff880`04a5e000 fffff880`04a5f480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`0189a000 fffff880`01a9e000   tcpip    tcpip.sys    Sat Nov 20 04:25:52 2010 (4CE79420)
fffff880`065d1000 fffff880`065e3000   tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`0187c000 fffff880`01889000   TDI      TDI.SYS      Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`0a14a000 fffff880`0a155000   tdtcp    tdtcp.sys    Mon Jul 13 20:16:32 2009 (4A5BCE60)
fffff880`0185a000 fffff880`0187c000   tdx      tdx.sys      Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`03f84000 fffff880`03f98000   termdd   termdd.sys   Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`00530000 fffff960`0053a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0a155000 fffff880`0a164000   tssecsrv tssecsrv.sys Sat Nov 20 06:04:09 2010 (4CE7AB29)
fffff880`0435f000 fffff880`04385000   tunnel   tunnel.sys   Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`04299000 fffff880`042ab000   umbus    umbus.sys    Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`0a1d3000 fffff880`0a1dd000   umpass   umpass.sys   Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`0895b000 fffff880`08978000   usbccgp  usbccgp.sys  Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`08978000 fffff880`08979f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`045c6000 fffff880`045d7000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05275000 fffff880`052cf000   usbhub   usbhub.sys   Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`04570000 fffff880`045c6000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04563000 fffff880`04570000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00fec000 fffff880`00ff9000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02e41000 fffff880`02e4f000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02e4f000 fffff880`02e74000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`01055000 fffff880`01091000   vmbus    vmbus.sys    Sat Nov 20 04:57:29 2010 (4CE79B89)
fffff880`01ae8000 fffff880`01af8000   vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00dbe000 fffff880`00dd3000   volmgr   volmgr.sys   Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01af8000 fffff880`01b44000   volsnap  volsnap.sys  Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`03f69000 fffff880`03f84000   wanarp   wanarp.sys   Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`02e74000 fffff880`02e84000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e00000 fffff880`00ea4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea4000 fffff880`00eb3000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03f2b000 fffff880`03f34000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00040000 fffff960`00351000   win32k   win32k.sys   Wed Jan 05 01:55:38 2011 (4D2415EA)
fffff880`01091000 fffff880`010a5000   winhv    winhv.sys    Sat Nov 20 04:20:02 2010 (4CE792C2)
fffff880`00fd9000 fffff880`00fe2000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`087b2000 fffff880`087d3000   WudfPf   WudfPf.sys   Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0646b000 fffff880`064dc000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01830000 fffff880`0183e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`02e9a000 fffff880`02fb6000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  0011C000
fffff880`02fb6000 fffff880`02fc9000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Thanks.
Updated the drivers I could. Reinstalled those I could not.
Will hope that this solves the problem. Will let you know if there are any more BSODs. Praying that there are not!
Thanks again.
