- Thread Author
- #1
Im trying to install the rc version of windows 7. First off i have an acer aspire 5610-4612. Now I cant even boot from the cd to begin installation and yes I've set usb cdrom, the only cd i see and i only have 1 cd rom drive, to the first boot priority. Next off here is a screenshot of my drives. I cant even access any removable devices including my cd rom drive :S. So I cant install from OS either. Im running build 7000 btw. Link Removed due to 404 Error
- Joined
- Mar 14, 2023
- Messages
- 38,685
It seems like you're encountering issues while trying to install the release candidate version of Windows 7 on your Acer Aspire 5610-4612. If you're having trouble booting from the CD drive and accessing removable devices, here are a few troubleshooting steps you can try:
Troubleshooting Steps:
- Check Boot Order:
- Ensure that the boot order is correctly set to prioritize the CD-ROM drive as the first boot device. This setting is usually found in the BIOS settings of your computer.
- Access the BIOS settings on your Acer Aspire 5610-4612 by pressing a specific key during the startup process (common keys are F2, Del, F12). Once in the BIOS, verify that the CD-ROM drive is recognized.
- Some computers allow you to access a boot menu by pressing a specific key during startup (common keys are F12, Esc). From the boot menu, you can directly choose to boot from the CD-ROM drive.
- Ensure that the Windows 7 installation disc is not damaged or scratched. Try using a different disc if possible to rule out any disc-related issues.
- If booting from the CD-ROM drive remains a challenge, consider creating a bootable USB drive with the Windows 7 installation files. You can use tools like Rufus to create a bootable USB.
Regarding the Drives:
From the screenshot you provided, it seems that there might be an issue with the drives not appearing correctly. If you're unable to access any removable devices, including the CD-ROM drive, here are a couple of additional steps you can take: - Check Device Manager:
- Go to Device Manager in Windows (if accessible) and check for any errors or warnings related to your CD-ROM drive and USB controllers.
- Update Drivers:
- If possible, try to update the drivers for your CD-ROM drive and USB controllers. This can sometimes resolve issues with device recognition. By following these steps, you should be able to troubleshoot and resolve the issues you are facing with installing Windows 7 on your Acer laptop. If you encounter any specific error messages or issues during the process, feel free to provide more details for further assistance.
Similar threads
- Replies
- 4
- Views
- 2K
- Replies
- 2
- Views
- 1K
- Replies
- 1
- Views
- 941
- Solved
- Replies
- 1
- Views
- 1K
- Replies
- 9
- Views
- 8K
