Windows 7 .net framework 4 still a problem
Asker24
As reported so often here by others, I just cannot stop Windows Update trying to update .net framework 4 files every night. I have followed all the suggestions I have seen here and on other forums, to no avail. Uninstall and reinstall (Y); total scan with three programs (Y); various microsoft fix-it suggestions (Y); All other updates (Y). If I run without it my wallpaper changer does not work but I have not explored what else I would miss.
Has anyone come up with a real solution for this one?
Dealing with persistent Windows Update issues can be frustrating. When facing problems with .NET Framework updates that keep failing, there are a few additional steps you can take to try and resolve this issue: 1. Manual Installation: - Download the specific .NET Framework update from the Microsoft Update Catalog. Then, manually install it on your system. This method can sometimes bypass any automatic update issues. 2. System File Checker: - Run the System File Checker tool to check for and repair corrupted system files. Here's how: - Open Command Prompt as an administrator. - Type sfc /scannow and press Enter. Let the scan complete. - Restart your computer and try Windows Update again. 3. Reset Windows Update...
Dealing with persistent Windows Update issues can be frustrating. When facing problems with .NET Framework updates that keep failing, there are a few additional steps you can take to try and resolve this issue: 1. Manual Installation: - Download the specific .NET Framework update from the Microsoft Update Catalog. Then, manually install it on your system. This method can sometimes bypass any automatic update issues. 2. System File Checker: - Run the System File Checker tool to check for and repair corrupted system files. Here's how: - Open Command Prompt as an administrator. - Type sfc /scannow and press Enter. Let the scan complete. - Restart your computer and try Windows Update again. 3. Reset Windows Update Components: - Sometimes, resetting the Windows Update components can resolve update issues. Follow these steps: - Open Command Prompt as an administrator. - Stop the BITS service, the Windows Update service, and the Cryptographic service by running the following commands:
 net stop bits net stop wuauserv net stop appidsvc net stop cryptsvc
- Rename the SoftwareDistribution and Catroot2 folders by executing these commands:
 ren C:\Windows\SoftwareDistribution SoftwareDistribution.old ren C:\Windows\System32\catroot2 Catroot2.old
- Restart the services stopped earlier:
 net start bits net start wuauserv net start appidsvc net start cryptsvc
4. Check Event Viewer: - Look into the Event Viewer for any error messages related to the .NET Framework update failures. This can provide more specific details about what might be causing the problem. 5. Third-Party Software Conflicts: - Sometimes, third-party software can interfere with Windows Update processes. Try temporarily disabling any security software or firewall and then attempt the update again. 6. Update Windows Manually: - In some cases, manually updating Windows to the latest version can resolve .NET Framework update issues. If you are still facing issues after trying these steps, it might be helpful to provide specific error messages or codes that appear when the updates fail. This information can assist in diagnosing the exact problem and finding a more tailored solution. Feel free to try these suggestions and let me know if you encounter any specific error messages during the update process.
