Tonchiki
I've run into a peculiar issue with a laptop I've obtained recently, a Sony Vaio VPCZ112GX. I'm able to connect to my wireless router, an ASUS RT-12 configured as an access point using the stock 1.0.0.6 firmware. However, despite a fully functioning network connection (I can ping other computers on the network successfully), I cannot obtain a stable internet connection using the laptop (both my desktop and netbook connect without issues). I use the qualifier "stable" because on two occassions in the past two weeks I've been able to access the internet for several hours before I lose internet connection again. I don't know what caused those bouts of connectivity, as both times it happened it was upon waking from sleep or hibernation. I've tried both updating and downgrading the drivers for the integrated card (Intel Centrino 6200), resetting the winsock and ipv4/v6 stacks, disabling ipv6 altogether, and finally culminated with a fresh install from the recovery discs. Nothing solved my issues. If anyone knows what the problem is, I'd be grateful if you could aid me!
tl;dr: Network connection works, internet connection doesn't. Information organized below.
Router: ASUS RT-12; Configured as Access Point; DHCP disabled so university routers provide DHCP when connected to LAN port of residential routers
Laptop with issue ; Intel Centrino 6200 B/G/N
C:\Windows\system32>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : moravaio
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : uci.edu
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : uci.edu
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6200 AGN
   Physical Address. . . . . . . . . : 00-23-14-41-84-74
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::adee:26b6:2a8d:dbc0%16(Preferred)
   IPv4 Address. . . . . . . . . . . : 169.234.103.77(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.192
   Lease Obtained. . . . . . . . . . : Monday, June 14, 2010 8:49:00 PM
   Lease Expires . . . . . . . . . . : Tuesday, June 15, 2010 2:55:12 AM
   Default Gateway . . . . . . . . . : 169.234.103.65
   DHCP Server . . . . . . . . . . . : 172.18.64.110
   DHCPv6 IAID . . . . . . . . . . . : 503325460
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-9F-45-66-00-1D-BA-C1-52-8A
   DNS Servers . . . . . . . . . . . : 128.200.1.201
                                       128.200.192.202
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Intel(R) 82577LC Gigabit Network Connecti
on
   Physical Address. . . . . . . . . : 00-1D-BA-C1-52-8A
Tunnel adapter isatap.uci.edu:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
   IPv6 Address. . . . . . . . . . . : 2002:a9ea:674d::a9ea:674d(Preferred)
                                       128.200.192.202
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 13:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{46C0F332-C448-430D-B84D-4FC4FEF99F71}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Desktop with no issues ; Rosewill RNX-EasyN1 B/G/N
   Host Name . . . . . . . . . . . . : morabox
   Description . . . . . . . . . . . : 802.11 USB Wireless LAN Card
   Physical Address. . . . . . . . . : 00-02-6F-65-11-B8
   Link-local IPv6 Address . . . . . : fe80::e4bd:1a73:758b:2e6e%12(Preferred)
   IPv4 Address. . . . . . . . . . . : 169.234.103.124(Preferred)
   Lease Obtained. . . . . . . . . . : Monday, June 14, 2010 8:43:54 PM
   Lease Expires . . . . . . . . . . : Tuesday, June 15, 2010 2:55:24 AM
   DHCPv6 IAID . . . . . . . . . . . : 218104431
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-95-25-62-48-5B-39-10-7F-EA
                                       128.200.192.202
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 48-5B-39-10-7F-EA
Tunnel adapter Local Area Connection* 18:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #11
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:28d5:394e:5615:9883(Pref
erred)
   Link-local IPv6 Address . . . . . : fe80::28d5:394e:5615:9883%14(Preferred)
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2
Tunnel adapter Reusable Microsoft 6To4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #3
Tunnel adapter Local Area Connection* 14:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #7
Tunnel adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #4
Tunnel adapter Local Area Connection* 12:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #5
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #6
Tunnel adapter Local Area Connection* 17:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #10
Tunnel adapter Local Area Connection* 15:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #8
Tunnel adapter Local Area Connection* 16:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #9
Tunnel adapter Local Area Connection* 20:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #13
   IPv6 Address. . . . . . . . . . . : 2002:a9ea:677c::a9ea:677c(Preferred)
   Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
                                       128.200.192.202
Tunnel adapter Local Area Connection* 19:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #12
Tunnel adapter isatap.{9C1620CA-77DB-47E5-8E06-4A0A03E63E7B}:
Netbook with no issues ; BCM4312 B/G
   Host Name . . . . . . . . . . . . : moramini
   Node Type . . . . . . . . . . . . : Broadcast
   Description . . . . . . . . . . . : Broadcom 802.11g Network Adapter
   Physical Address. . . . . . . . . : 00-23-08-49-08-DB
   Link-local IPv6 Address . . . . . : fe80::e514:a7f4:56b2:e619%12(Preferred)
   IPv4 Address. . . . . . . . . . . : 169.234.104.55(Preferred)
   Lease Obtained. . . . . . . . . . : Monday, June 14, 2010 7:43:02 PM
   Lease Expires . . . . . . . . . . : Tuesday, June 15, 2010 1:43:02 AM
   Default Gateway . . . . . . . . . : 169.234.104.1
   DHCPv6 IAID . . . . . . . . . . . : 218112776
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-0F-12-B6-00-21-70-D8-2D-D4
                                       128.200.192.202
   Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
   Physical Address. . . . . . . . . : 00-21-70-D8-2D-D4
Tunnel adapter Local Area Connection* 22:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #14
Tunnel adapter Local Area Connection* 29:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #20
Tunnel adapter Local Area Connection* 21:
Tunnel adapter Local Area Connection* 25:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #17
Tunnel adapter Local Area Connection* 23:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #15
Tunnel adapter Local Area Connection* 24:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #16
Tunnel adapter Local Area Connection* 26:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #18
Tunnel adapter Local Area Connection* 27:
   IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e74:2474:8b4:5615:97c8(Prefe
rred)
   Link-local IPv6 Address . . . . . : fe80::2474:8b4:5615:97c8%34(Preferred)
Tunnel adapter Local Area Connection* 28:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #19
Tunnel adapter Local Area Connection* 30:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter #21
   IPv6 Address. . . . . . . . . . . : 2002:a9ea:6837::a9ea:6837(Preferred)
                                       128.200.192.202
Tunnel adapter isatap.{E23A3BBF-30F0-4B7A-ADC5-038BA546FB9A}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Plugging my desktop's usb wireless adapter into my laptop with issues allows internet connection, but I'd prefer using the integrated wireless card on my laptop if possible. Any suggestions?
The IP information looks good for the problem laptop and I would assume that since you can ping other network nodes that the driver is working ok, and since another wireless adapter provides a good connection it would seem that your AP is not an issue, with the trouble shooting and diagnostics you've done so far, the only thing that I could find to add which may or may not help follows;
Make sure
Maximum Performance is selected for Wireless Adapter Settings in the Power Options window. Selecting any other option may result in a communication failure. To change the settings, follow...
Make sure
Maximum Performance is selected for Wireless Adapter Settings in the Power Options window. Selecting any other option may result in a communication failure. To change the settings, follow these steps:
1 Right-click the power status icon on the taskbar and select Power Options.
2 Click Change plan settings.
3 Click Change advanced power settings.
4 Select the Advanced settings tab.
5 Double-click Wireless Adapter Settings and Power Saving Mode.
6 Select Maximum Performance from the drop-down list both for On battery and Plugged in.
SOURCE: = Page 174 of Sony Vaio user manual.
I would actually take one additional step and open device manager, expand network adapaters, right click on the problem wireless adapter, choose properties and under the "Power Management Tab" uncheck "Allow the computer to turn off this device to save power".
Hope this helps.
Unfortunately, those settings didn't change anything. At this point I'm suspecting some sort of incompatibility between my school's network and the built-in wireless card (I've attempted to connect to other routers with the same configuration and encountered the same issues). I'll try replacing the internal card using one off ebay whenever I have the time this summer, and if that doesn't work, just resign myself to an external adapter. Thanks for the help!
