No Sound on DV1000 Laptop
Just installed Win7 Pro on my dv1000 (specifically dv1680ca) and I have no sound. I had to initially install a driver from HP's website (only drivers for XP and Vista were available) for windows to see that I had speakers at all, not it thinks I have sound (sound animation in taskbar), but no sound.
I do get sound when I plug in my headphones, but nothing from the speakers. The same problem came up with Vista, but the driver seemed to work that time.
I was browsing their website, and this link seems to suggest that my computer won't be supported with windows 7?
If that's the case.... DAMMIT!
Windows Forum Admin
Microsoft MVP
Hi Sloanstife,
have you tried running the drivers in compatibility mode? If that fails try running windows update.... You never know...
reghakr
Could you give us the exact make and model of your sound card?
Go to Start > Run, type msinfo32, expand the Components section and click on the Sound Device
Windows Forum Admin
Microsoft MVP
Saltgrass
It seems to me Windows 7 drivers do not include support for legacy type devices. Possibly why some folks can't get speakers to work, since adding more drivers will usually solve the problem, hopefully not drivers that will cause conflicts.
