Outlook and ICloud
librim
Hello
Since I installed icloud on win7 computer it has messed all my settings in my outlook 2007.
Now when I go to email something- it tells me that the contact is not there, however it is there but in another folder the icloud made.
Even my calender changed- it added a icloud calender that does not have all my appointments.
Does any one know how to change the default Contacts and calender back to the original that Outlook was using?
Can I remove icoud from my computer with out causing more havoc?
Thanks in advance for ANY help.
PB
Gavin Oscur
Well-Known Member
To Uninstall Icloud on Windows 7, please follow the steps are given below:-
  • Go to the control panel click on programs and then click uninstall/change program
  • Find iCloud then double click in it and follow the instructions.
Change the Default Outlook Data File
