Windows 10 Please Help Me
Pleacido
Lately ... my Windows 10 suddenly having so many problems ... I can't access the Play store even Cortana isn't working :( ... Please Help Me How To Fix This :(
0W30LZo
Sounds like your Windows install is corrupt. You can try running one or more of the following commands to attempt a repair from an elevated command prompt
  • chkdsk /f /r t then press Y to run it at the next reboot and reboot
  • DISM /Online /Cleanup-Image /RestoreHealth
If neither of those resolves the issue you can do a re-install over the existing install, you will just need to download the ISO and create a bootable media
If that doesn't work, then you are looking at a clean install which will wipe out everything, so if you have data be sure to back it up.
:( I can't access any of the features of Windows 10 :(
How to solve 'so many problems'....
Try in-line re-install > All settings > repair....
