Windows 7 Please help me
siehbi
I have been having BSoD's for a few days. 1 day ago was the worst. let me start over. a week ago i chucked in a new gpu and a sound card. at that time i had the drivers intalled and all worked fine. about a week later bluescreens started joining the club. i had memory managment. sadly i dont have the .dmp files. i formatted and started a fresh install of windows 7 x64. now when ever i get a bluescreen i have to go into my bios and adjust the boot order to start from windows cause otherwise it askes me to insert a hdd then after the logo another bluescreen, startup repair, another blue screen, then ok starts up.
My specs:
cpu: intel i5 3570k (not over clocked)
memory: corsair ddr3 xms3 8gb (2x4)
motherboard: asus p8z77-v
gpu: EVGA GTX 660Ti
sound card: creative sound blaster Zx
PSU: 750W antec true power
hdd: seagate baracuda 1Tb
if files attached arent available go to : https://www.box.com/s/fzzvhk2lqne82nioo1dv
  • 042213-20389-01.dmp
  • 042213-20904-01.dmp
  • 042213-22214-01.dmp
  • 042213-25178-01.dmp
usasma
Fantastic Member
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
For starters:
At work we start all repairs with a set of diagnostics. Often they find problems that weren't even expected. It's a waste of time to try to fix software on a system that has hardware problems.
Please try these free diagnostics for starters: Initial Hardware Diagnostics
Also, please ensure that you have ALL available Windows Updates (it may take several trips to get them all).
I suspect an error with your RAM - so start with the MemTest86+ diagnostic above.
SP1 isn't installed, please do the following:
Installing Windows 7 Service Pack 1
1. Visit the PC manufacturer's website and update ALL drivers. DO NOT use Windows Update or the "Update drivers" function of Device Manager.
2. Check Device Manager for any unknown/disabled devices - if there are unknown/disabled devices, fix them with the latest drivers from the device manufacturer's website (not the PC Manufacturer)
3. Visit Windows Update and get all updates (may take repeated visits)
4. Visit Windows Update and get Service Pack 1 (usually under Important Updates). Read these notes for installing SP1: Steps to follow before you install Windows 7 SP1 and Windows Server 2008 R2 SP1 from the Microsoft Download Center
5. Visit Windows Update and get any other available updates. May take repeated visits, but keep it up until you get several "Windows is updated" results.
If you're having difficulties with installing a Service Pack, please use the SURTool from this link: What is the System Update Readiness Tool?
Also, check out this troubleshooting link from Microsoft: Troubleshoot problems installing Service Pack 1 (SP1) for Windows 7 and Windows Server 2008 R2
I have had limited success in installing updates/Service Packs when using a "clean boot". I suspect that I'm just bypassing the problem - and that it can come back to bite me in the butt later on.
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Mon Apr 22 14:52:40.648 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042213-20389-01.dmp]
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
[B][COLOR=RED]Missing Windows 7 Service Pack 1[/COLOR][/B]
Built by: [B]7600[/B].16385.amd64fre.win7_rtm.090713-1255
System Uptime:[B]0 days 0:04:04.741[/B]
Probably caused by :[B]hardware_ram ( ZEROED_PAGE_CORRUPTED )[/B]
BugCheck [B]1A, {8887, fffffa80009b7000, fffffa8003d3f8c0, 105}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001A"]MEMORY_MANAGEMENT (1a)[/URL]
Arguments:
Arg1: 0000000000008887, The subtype of the bugcheck.
Arg2: fffffa80009b7000
Arg3: fffffa8003d3f8c0
Arg4: 0000000000000105
BUGCHECK_STR:  0x1a_8887
PROCESS_NAME:  WerFault.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_8887_ZEROED_PAGE_CORRUPTED[/B]
CPUID:        "Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz"
MaxSpeed:     3400
CurrentSpeed: [B]3410[/B]
  BIOS Version                  1805
  BIOS Release Date             12/19/2012
**************************Mon Apr 22 14:47:18.870 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042213-20904-01.dmp]
System Uptime:[B]0 days 0:00:13.963[/B]
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
Probably caused by :[B]dxgkrnl.sys ( dxgkrnl+87970 )[/B]
BugCheck [B]1A, {1236, fffffa80068ce3d0, fffffa80068ce408, dbbab}[/B]
Arguments:
Arg1: 0000000000001236, The subtype of the bugcheck.
Arg2: fffffa80068ce3d0
Arg3: fffffa80068ce408
Arg4: 00000000000dbbab
BUGCHECK_STR:  0x1a_1236
PROCESS_NAME:  csrss.exe
FAILURE_BUCKET_ID: [B]X64_0x1a_1236_dxgkrnl+87970[/B]
**************************Mon Apr 22 14:32:53.240 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042213-25178-01.dmp]
System Uptime:[B]0 days 1:12:17.333[/B]
*** WARNING: Unable to verify timestamp for kl1.sys
*** ERROR: Module load completed but symbols could not be loaded for kl1.sys
Probably caused by :[B]kl1.sys ( kl1+3bc80a )[/B]
BugCheck [B]50, {fffff8800ad70ec6, 0, fffff80003059063, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000050"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: fffff8800ad70ec6, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80003059063, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  avp.exe
FAILURE_BUCKET_ID: [B]X64_0x50_kl1+3bc80a[/B]
MaxSpeed:     3400
  BIOS Version                  1805
**************************Mon Apr 22 12:38:45.570 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042213-22214-01.dmp]
System Uptime:[B]0 days 0:06:04.037[/B]
*** WARNING: Unable to verify timestamp for iaStor.sys
*** ERROR: Module load completed but symbols could not be loaded for iaStor.sys
Probably caused by :[B]iaStor.sys ( iaStor+2cab3 )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff88006a31ab3, fffff880031cb558, fffff880031cadb0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x1000007E"]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/URL]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff88006a31ab3, The address that the exception occurred at
Arg3: fffff880031cb558, Exception Record Address
Arg4: fffff880031cadb0, Context Record Address
PROCESS_NAME:  System
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_iaStor+2cab3[/B]
MaxSpeed:     3400
  BIOS Version                  1805
[/FONT]
3rd Party Drivers:
amdxata.sys                 Tue May 19 13:56:59 2009 (4A12F2EB) (EDIT: removed Bold Red from this driver)
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
klmouflt.sys                Mon Nov  2 11:26:06 2009 (4AEF081E)
kl2.sys                     Fri Mar  4 04:17:31 2011 (4D70AE2B)
kl1.sys                     Fri Mar  4 04:20:03 2011 (4D70AEC3)
klim6.sys                   Thu Mar 10 09:36:02 2011 (4D78E1D2)
e1c62x64.sys                Wed Jul 20 12:37:53 2011 (4E270461)
athrx.sys                   Fri Oct 21 05:45:10 2011 (4EA13F26)
asmtxhci.sys                Wed Nov  2 23:00:22 2011 (4EB203C6)
asmthub3.sys                Wed Nov  2 23:00:32 2011 (4EB203D0)
HECIx64.sys                 Wed Nov  9 19:52:25 2011 (4EBB2049)
iaStor.sys                  Tue Nov 29 22:39:19 2011 (4ED5A567)
asahci64.sys                Thu Jan  5 00:08:19 2012 (4F053043)
iusb3hub.sys                Thu Jan  5 06:54:43 2012 (4F058F83)
iusb3xhc.sys                Thu Jan  5 06:54:45 2012 (4F058F85)
iusb3hcs.sys                Thu Jan  5 06:56:40 2012 (4F058FF8)
RTKVHD64.sys                Tue Feb 14 05:55:35 2012 (4F3A3DA7)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
klif.sys                    Tue Sep 25 10:28:18 2012 (5061BF82)
cthda.sys                   Tue Oct  2 04:14:14 2012 (506AA256)
cthdb.sys                   Tue Oct  2 04:14:18 2012 (506AA25A)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
klif.sys                    Wed Apr 20 06:34:31 2011 (4DAEB6B7)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=klmouflt.sys
http://www.carrona.org/drivers/driver.php?id=kl2.sys
http://www.carrona.org/drivers/driver.php?id=kl1.sys
http://www.carrona.org/drivers/driver.php?id=klim6.sys
http://www.carrona.org/drivers/driver.php?id=e1c62x64.sys
http://www.carrona.org/drivers/driver.php?id=athrx.sys
http://www.carrona.org/drivers/driver.php?id=asmtxhci.sys
http://www.carrona.org/drivers/driver.php?id=asmthub3.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=asahci64.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hub.sys
http://www.carrona.org/drivers/driver.php?id=iusb3xhc.sys
http://www.carrona.org/drivers/driver.php?id=iusb3hcs.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=klif.sys
cthda.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
cthdb.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
siehbi
I did try running memtest 86+. first time it gave me 2 errors and then after running it again to make sure there were no problems. i didn't change the configuration or placement of the ram sticks. i also got a few more blue screens but this time it was the PFN blue screen. this is getting really annoying. also memtest 86+ stayed running for 2 hours for both tries.
  • 042313-20482-01.dmp
  • 042313-34023-01.dmp
  • 042313-37128-01.dmp
siehbi
i have now deleted amdxata.sys and no bluescreens have shown up during normal use. but when i tried playing ghost recon online i got a blue screen. the .dmp file is attached. can you please give me details on the .dmp file
  • 042313-44007-01.dmp
usasma
Fantastic Member
It is my mistake, but you shouldn't have deleted amdxata.sys. This problem will be resolved if you update to SP1. You will also need to get ALL Windows Updates after SP1 (about 150 in most systems)
I requested this info in my previous post: Blue Screen of Death (BSOD) Posting Instructions
I have requested that you run these hardware diagnostics (to include at least 3 passes of MemTest86+): Initial Hardware Diagnostics It also states that if all diagnostics pass, please run the diagnostics here: Additional Hardware Diagnostics
Please report back the results of each of the diagnostics when completed.
There are enough signs here that that I have to wonder about this installation. Should this be a pirated copy of Windows, please be aware that we may not be able to fix it (as the hacks that were done to activate it will cause the OS to behave differently than we expect it to). If that's the case, our efforts to help may just waste your time. Secondly, the forum rules prohibit assisting with pirated software - so the topic would be closed if that is the case.
siehbi
sorry for late reply
i have changed hardrives and situation has improved but still get the occasional BSOD. service pack 1 is installed all drivers are up to date and i am uploading the files that you requested with that program. i am getting blue screen when i play ghost recon online. Also my windows is genuine.
  • SF_25-04-2013.zip
usasma
Fantastic Member
Only 107 Windows Updates installed. Most systems have 150 or more. Please visit Windows Update and get ALL available updates (it may take several trips to get them all).
Realtek High Definition Audio is disabled. Is this deliberate? If so, why?
(it looks like you have a Creative Sound Blaster card, so that may be the reason)
Out of 3 memory dumps there were 3 different BSOD error codes. The differing error codes may be symptomatic of a lower level problem within the system (I usually like to see 4 or 5 memory dumps before coming to this conclusion). They are usually caused by one of these things:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers)
- low-level driver problems
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
As such, please start with these free hardware diagnostics: Hardware Diagnostics
Analysis:
[font=lucida console]**************************Thu Apr 25 15:35:52.841 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042513-32229-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 0:19:51.871[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+13702 )[/B]
BugCheck [B]1A, {41201, fffff6800039d018, 286000016f35e025, fffffa800bcbca00}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000001A]MEMORY_MANAGEMENT (1a)[/url]
Arguments:
Arg1: 0000000000041201, The subtype of the bugcheck.
Arg2: fffff6800039d018
Arg3: 286000016f35e025
Arg4: fffffa800bcbca00
BUGCHECK_STR:  0x1a_41201
FAILURE_BUCKET_ID: [B]X64_0x1a_41201_nt!_??_::FNODOBFM::_string_+13702[/B]
MaxSpeed:     3400
  BIOS Version                  1805
**************************Thu Apr 25 15:15:23.136 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042513-57252-01.dmp]
System Uptime:[B]0 days 2:55:55.151[/B]
Probably caused by :[B]win32k.sys ( win32k+5d018 )[/B]
BugCheck [B]3B, {c0000005, fffff960000cd018, fffff8800c8e42b0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000003B]SYSTEM_SERVICE_EXCEPTION (3b)[/url]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff960000cd018, Address of the instruction which caused the bugcheck
Arg3: fffff8800c8e42b0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME:  Suite2.exe
FAILURE_BUCKET_ID: [B]X64_0x3B_win32k+5d018[/B]
MaxSpeed:     3400
  BIOS Version                  1805
**************************Wed Apr 24 16:21:56.863 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\042413-24991-01.dmp]
System Uptime:[B]0 days 1:52:37.346[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+16e06 )[/B]
BugCheck [B]4E, {7, 1a7192, 1a7185, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000004E]PFN_LIST_CORRUPT (4e)[/url]
Arguments:
Arg1: 0000000000000007, A driver has unlocked a page more times than it locked it
Arg2: 00000000001a7192, page frame number
Arg3: 00000000001a7185, current share count
Arg4: 0000000000000000, 0
BUGCHECK_STR:  0x4E_7
PROCESS_NAME:  GhostReconOnli
FAILURE_BUCKET_ID: [B]X64_0x4E_7_nt!_??_::FNODOBFM::_string_+16e06[/B]
MaxSpeed:     3400
  BIOS Version                  1805
[/font]
3rd Party Drivers:
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
lvbflt64.sys                Wed Jan 18 01:39:53 2012 (4F166939)
lvrs64.sys                  Wed Jan 18 01:40:36 2012 (4F166964)
lvuvc64.sys                 Wed Jan 18 01:41:08 2012 (4F166984)
HECIx64.sys                 Mon Jul  2 18:14:58 2012 (4FF21D62)
nvlddmkm.sys                Fri Jan 18 08:22:15 2013 (50F94C87)
cthda.sys                   Sun Mar 24 23:03:12 2013 (514FBE70)
cthdb.sys                   Sun Mar 24 23:03:17 2013 (514FBE75)
[/font]
http://www.carrona.org/drivers/driver.php?id=lvbflt64.sys
http://www.carrona.org/drivers/driver.php?id=lvrs64.sys
http://www.carrona.org/drivers/driver.php?id=lvuvc64.sys
