Jason Chong
Operating System: Windows 7 Home Premium
I recently got this Samsung R440 laptop and I've been having trouble installing downloaded programs, (ex. AOL IM, iTunes).
Itunes won't even appear when I run the installer. AOL will say "NSIS Error: Error Launching Installer".
I've tried numerous things: run as admin, cmd.exe (force install), and changed .exe into .msi. I'm wondering if this may be a problem with the registry, however I've even used Registry Cleaner with no luck.
Does anyone have a solution? Do you need to look at my cmd.exe (/ stat)? hijack this? anything else?
Thanks.
It seems like you have encountered issues while trying to install programs on your Samsung R440 laptop running Windows 7 Home Premium. The errors you mentioned, such as the "NSIS Error" with AOL and iTunes not appearing when running the installer, can be frustrating but are usually fixable. Here are some steps you can take to troubleshoot and potentially resolve these installation issues:
Troubleshooting Steps:​
  1. Check for System Requirements: Ensure that the programs you are trying to install are compatible with Windows 7 and meet the system requirements of your laptop.
  2. Download Corrupted Files: Sometimes, downloads can get corrupted. Try re-downloading the installers for iTunes and AOL Instant Messenger to...
  2. Download Corrupted Files: Sometimes, downloads can get corrupted. Try re-downloading the installers for iTunes and AOL Instant Messenger to rule out file corruption issues.
  3. Disable Antivirus/Firewall: Temporarily disable your antivirus and firewall software before installing the programs. Sometimes, security software can interfere with installations.
  4. NSIS Error Fix:
    • The "NSIS Error" you encountered with AOL may be due to an issue with the compressed installer.
    • You can try the following steps to fix the NSIS Error:
      • Check if the installer is not corrupt or incomplete.
      • Rename the installer file to a simple one-word name and try running it again.
    []iTunes Installation:
    • If iTunes is not appearing, try right-clicking on the iTunes installer and selecting "Run as administrator." This can help bypass any permission-related issues.
    • You can also try compatibility mode: Right-click on the installer, go to Properties > Compatibility, and try installing in compatibility mode for Windows 7.
    ]Registry Cleaners: While registry cleaners can sometimes help, they should be used with caution. Incorrect registry cleaning can cause more harm than good. Be careful when using such software. []System File Checker (SFC): Run the System File Checker tool to scan for and repair corrupted system files. Open Command Prompt as an administrator and type: sfc /scannow []HijackThis: Running HijackThis can help identify potential issues with startup programs and malicious entries in the registry. However, only advanced users should use this tool as it can have unintended consequences if used incorrectly.
  5. Event Viewer: Check the Windows Event Viewer for any error messages related to the installation process. It might provide more specific details on what is going wrong. Feel free to try these steps and let me know if you encounter any specific errors or issues during the process. If needed, we can delve into more advanced troubleshooting methods.
