- Thread Author
- #1
About a year ago, I did a clean install from vista 32 bit to Windows 7 professional 64 bit. Everything went smoothly and I had no installation issues. A couple of days ago, my hard drive crashed so I put in a new one and used my computer's recovery cd to load windows xp back on the system. I then did a clean install to windows 7 using the same dvd from a year ago. Just before finishing, I received the error message "windows setup could not configure windows to run on this computer's hardware," which is now running in an endless loop. I don't understand why this would be an issue since everything is the same as before (I had upgraded the video card to radeon and soundcard to sound blaster, but after receiving first error message, I removed them and went back to original hardware).
I then thought I would start the whole thing over again and go back to windows xp and possibly install windows vista before trying windows 7 again. But now when I put the recovery cd in, I get the message "asc3350p.sys is corrupted" so I can't reinstall windows xp either.
My setup:
Dell dimension E520
intel dual core 2.8ghz processor
1tb western digital caviar green hard drive
6gb ram
Windows 7 was downloaded iso
Thank you for any help you can give
My setup:
Dell dimension E520
6gb ram
- Joined
- May 16, 2010
- Messages
- 5,703
Where was your iso downloaded from?Windows 7 was downloaded iso
- Thread Author
- #3
- Thread Author
- #4
- Thread Author
- #5
That fixed the problem. Here is a link in case anybody else encounters this problem
“Windows Setup could not configure Windows on this computer’s hardware” installation error on a Windows 7-based or a Windows Server 2008 R2-based computer
Similar threads
- Replies
- 2
- Views
- 2K
- Replies
- 6
- Views
- 6K
- Solved
- Replies
- 2
- Views
- 4K
- Replies
- 8
- Views
- 6K
- Solved
- Replies
- 2
- Views
- 6K
