Windows 7 rear panel 3.5mm jack not working (RED)
lazeris205
Hello everyone so the problem is that my 3.5mm jack not working maybe its disabled or its problem with something else please help me thats what my computer is showing me when i plug in my microphone it says that my microphone is not plugged in but headphones working normally and it showing me that line in is not plugged in please help i will be grateful if you help me my motherboards: ASrock G41C-GS / G41C-S OS:windows 7 Ultimate and sound card: VIA HD audio deck
It seems like you are experiencing issues with the 3.5mm jack on your computer, specifically with the microphone not being recognized while headphones are working normally. This could be due to the microphone port being disabled or encountering other problems. Here are some steps you can take to troubleshoot and potentially resolve the issue:
Troubleshooting Steps for 3.5mm Jack Issue:​
  1. Check Microphone Connection:
    • Ensure that the microphone is properly plugged into the correct port (usually the pink port) on your computer.
    []Enable Microphone in Sound Settings:
    • Right-click on the speaker icon in the system tray and select "Recording devices."
    • Check if the microphone is listed and...
    • Check if the microphone is listed and enabled. If not, right-click on it and enable it.
    ]Update Sound Drivers:
    • Outdated or corrupt sound drivers can cause issues. Update your VIA HD audio drivers to the latest version. You can download them from the ASRock website or VIA's official site.
    []Check Sound Settings in BIOS:
    • Sometimes, audio ports can be disabled in the BIOS settings. Enter the BIOS setup during boot (usually by pressing Del or F2) and ensure that the audio ports are enabled.
    ]Test with Another Microphone:
    • Try using a different microphone to determine if the issue is with the microphone itself.
    []Reinstall Audio Drivers:
    • Uninstall the current VIA HD audio drivers from the Device Manager and then reinstall them. This can sometimes fix driver-related issues.
    ]Windows Troubleshooter:
    • Run the built-in Windows Troubleshooter for audio problems. It can detect and resolve common sound issues.
  2. Check Microphone Privacy Settings:
    • In Windows, go to Settings > Privacy > Microphone and ensure that microphone access is allowed for apps.
      Additional Information:​
      • Motherboard: ASRock G41C-GS / G41C-S
      • Operating System: Windows 7 Ultimate
      • Sound Card: VIA HD Audio Deck
      By following these steps, you may be able to identify and resolve the issue with the microphone not being recognized through the 3.5mm jack on your computer. Let me know if you need further assistance or if you have any other questions!
