wyliec2
I have migrated from Windows Server 2012 Essentials which required the server to be a domain controller to Windows Server 2022 Standard.
I removed the old server from operation and no longer have or want a domain controller.
I just need to establish basic shared folder access from client PCs to the server.
When I try to connect a client PC (Windows 11), I get an error "Cannot contact a domain controller to service this request".
I have removed the old Essentials connector, I have removed the domain from computer name, I have removed the dns address from network setup but it still seems to be looking for a non-existent domain controller.
The only way around this I've found is with a clean install of Windows so that it was never connected to an Essentials environment....
How do I fix this without doing clean installs??
You’re experiencing a classic “domain-ghosting” issue: after removing your domain controller and changing your Windows 11 client to a workgroup, residual domain settings and cached credentials can still cause it to look for the old domain controller—hence the "Cannot contact a domain controller" error.
Here’s how you can cleanly “de-domain” the clients without a full reinstall:
1. Remove Domain User Profiles​
  • Even after leaving the domain, Windows keeps domain profiles on disk, and sometimes background services and logon scripts may reference domain resources.
  • Manual fix:
  • On the Windows 11 client, open “Settings” > “Accounts” > “Access work or school.”
  • Remove any domain accounts listed.
  • Open...
  • Manual fix:
  • Open File Explorer and go to C:\Users. Manually remove any folders/personal data associated with old domain users (if you don’t need them—or migrate the data to your new local account first).
2. Check “User Accounts” and Login Methods​
  • Go to Control Panel > User Accounts > Manage User Accounts.
  • If any old “domain\username” style accounts are still listed, remove them.
3. Remove Windows Credentials​
  • Domain credentials can be stored and cause login confusion.
  • Open Credential Manager (Control Panel > Credential Manager).
  • Remove any entries under “Windows Credentials” or “Generic Credentials” referring to the old domain.
4. Reset Network Profile​
  • Sometimes, network settings still have traces of the old domain DNS or dependencies.
  • Open an elevated Command Prompt and enter:
    netsh int ip reset
    ipconfig /flushdns
  • Then, in Network Settings, make sure your PC is connected to a WORKGROUP (not a domain) and no custom DNS entries remain.
5. Housekeeping with netdom and Registry (if needed)​
  • Open regedit and check for any lingering domain policies:
  • Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Group Policy
  • Also check for: HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Domain
  • If the value is your old domain, change it or remove the entry.
6. Always Login with a Local Account Moving Forward​
  • Never try to log in using the old “domain\user” format.
  • If you don’t have a local account with admin rights, boot into Safe Mode and create one:
  • Settings > Accounts > Family & other users > Add someone else to this PC.
Note​
For many, these steps are enough. But if a system was especially domain-managed (heavy GPO use, mandatory profiles, redirected folders, etc., sometimes stubborn domain links can remain—most often fixed by deleting the profile and starting with a clean local account.
Several admins confirm that a full clean install is not required unless you've got a really borked machine.
Recap (TL;DR)​
  • Remove all domain profiles.
  • Remove domain credential references in Credential Manager.
  • Ensure the PC is in a workgroup and not using domain DNS.
  • Make sure you're logging in as a local user.
  • Clean up old domain registry or policy hints.
After a reboot, your Windows 11 PC should stop trying to contact the old domain and will happily work in a pure workgroup/shared folder configuration.
If you get stuck on any specific step or see a cryptic error, let me know—happy to break it down further!
Mike
Windows Forum Admin
Remove-Computer -UnjoinDomainCredential "OldDomain\Admin" -WorkGroupName "WORKGROUP" -Verbose -Restart
wyliec2
Would this be under Power Shell?? Not recognized in elevated Command Prompt...
