Windows 7 Repair or delete iassdo.dll.mui
TrojanHorse27
When i run sfc/scannow now in my computer i get an error as the some files cannot be repaired please help to delete or repair the file. (attached reports and snap shot)
Regards
Trojan
  • CBS.zip
    CBS.zip
If you check the link, it will go through how to repair a system using information obtained with the SFC. But on the site it refers to this command:
findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log >%userprofile%\Desktop\sfcdetails.txt
You can open an administrative command prompt, copy this command and paste it into the command window using the right click option, and it will create the SFCdetails.txt on your desktop.
The link shows how to look for the problem files so you can try to replace them. I do have the file you mention on my system.
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
I will look at your CBS.log to see what files may be involved.
I downloaded the one on CNET, but it won't do you any good. Since two of my files have different hashes, it could be another reference is used to compare the files. Since the iassdo.dll.mui file might be related to some type of Network security, there may be a key checked to confirm the file.
All I can suggest is a completely clean install to test. If you did it on a new or old drive, it would not interfere with your current install.
But if you do a reinstall or recovery and you still have the same problem, the file or what might be causing the problem is in that system somehow.
Now i feel to leave the problem as it is as so for i have reinstalled my OS four times now but yet the result is the same hence
i request the admin to close this post :(
Thanks to all for the support
He
2017-10-21 23:12:20, Info                  CSI    00000342 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2017-10-21 23:12:20, Info                  CSI    00000344 [SR] Cannot repair member file [l:28{14}]"iassdo.dll.mui" of Microsoft-Windows-Networking-Internet_Authentication_Service_Iassdo.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2017-10-21 23:12:20, Info                  CSI    00000345 [SR] This component was referenced by [l:266{133}]"Microsoft-Windows-WindowsFoundation-LanguagePack-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.Windows Foundation Language Pack"
2017-10-21 23:12:20, Info                  CSI    00000348 [SR] Could not reproject corrupted file [ml:60{30},l:58{29}]"\??\C:\Windows\SysWOW64\en-US"\[l:28{14}]"iassdo.dll.mui"; source file in store is also corrupted
Try running sfc a number of times and see if it repairs the file. Post back if it still refuses to repair.
Hello
Please tell me how to repair this iassdo.dll.mui file .It has been corrupted and I have done all the steps to repair it but none worked . Above I have uploaded the sfcdetails.txt
ok
Also try running sfc in safe mode.
