Okay. I upgraded one of my computers from 7 Home Premium to 8.1 Pro last week. Had trouble with a PCI-E card which turned out to be a defective PCI-E slot in the MOBO(had to perform several shut downs after lock ups) . On Saturday I had time to check to see if the image was healthy with the command "dism /online /cleanup-image /scanhealth".
After the scanhealth completed it gave me this "The component store is repairable. The operation completed successfully."
I then ran "dism /online /cleanup-image /restorehealth". and the result is
"Error: 0x800f0906" The source files could not be downloaded. Use the "source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see
Link Removed."
Here are the options to Configure a Windows Repair Source:
"You can use a mounted Windows image from a WIM file as a source to restore optional features and repair a corrupted operating system. For example, c:\test\mount\Windows. For more information about capturing a Windows image as a WIM file, see
Capture Images of Hard Disk Partitions Using DISM.
- You can use a running Windows installation as a source to restore optional features by sharing the c:\Windows folder on your network.
- You can use a Windows side-by-side folder from a network share or from a removable media, such as the Windows DVD, as the source of the files. For example, z:\sources\SxS.
- You can use a Windows image (.wim) file on a network share as a source to restore optional features. You must specify the index of the Windows image in the .wim file that you want to use and you must use a Wim: prefix in the path to identify this file format. For example, to specify index 3 in a file named contoso.wim, type: Wim:\\network\images\contoso.wim:3."
I have connected the computers through my LAN and should be able to use the shared the c:\Windows folder from my second computer running 8.1 Pro also.
I need the command line to do this.
The attached file is what I found in the DISM Log for this error. I only include the warnings and errors that were listed.
Thanks so much for your help,
Ken
