The thread discusses a tutorial on resetting metro-style Windows applications like Cortana and Microsoft Edge by renaming their folders and re-registering them via PowerShell. The original poster provides detailed steps for the process, while a subsequent user indicates they relocated their question elsewhere. Overall, the thread focuses on troubleshooting app resets, with no significant issues or solutions beyond the instructions provided.
Thread Author
This tutorial will help you reset any metro style application, this includes Cortana and Microsoft Edge
  1. Open Windows Explorer (Windows Key + e)
  2. Navigate to C:\Users\<username>\Appdata\Local\Packages
    1. Shortcut: Type %LOCALAPPDATA%\Packages in the address bar
  3. The folders should be in the format Publisher.Application.ID locate the folder for the application you wish to reset, right click and rename it. I tend to just append .old
  4. Open an elevated powershell prompt (Press Windows Key, type powershell, right click "Windows Powershell" and select Run as Administrator
  5. Type Get-AppxPackage -name "*MicrosoftEdge*" | ForEach { "$($_.InstallLocation)\AppxManifest.xml" | Add-AppxPackage -DisableDevelopmentMode -Register }
Replace the text in between "* *" with your application you are resetting -name "*MicrosoftEdge*"
Your application should now be reset.
MikeHawthorne
Moved my question to another location!!!
