Windows 7 Right Click Menu customization
D-11
Hi, D-11 again with my annoying questions ;) So... Is the Right Click menu open for customization? Like removing commands you don't want/need? Because always when I save pics to my HDD I click on Send Image... instead of Save As...
This is related to Firefox, not Windows so not sure why you're asking here but whatever. To get rid of certain menu entries (context menu or main menu) within Firefox, you need to download this add-on. Deselect the entries you want to be taken out and that is all there is to it
Menu Editor
Link Removed due to 404 Error
Just look at the name in the context menu and locate that item in the program, simpleas that.
Yeah but I only have like... 20-25 items marked Context Menu
Where, in the program or on your context menu
Could you give me a screen shot of one you want to remove?
Many programs give you the opportunity to disable the shell extension. i suggest you open the programs and look through the options.
I want the highlighted option and the one below it gone
That is from a 3rd party program and like I said go into the options and uncheck the context menu entry.
It's not built-into Windows 7.
If you know the name of the program, give me a link and I'll install it on my PC and see what I can do.
But which context menu entry is it then! I've disabled everyone that doesn't give me a warning and they don't do squat
Have you rebooted.
That context menu entry looks like it comes from a graphic program,
Do you know the name of the program?
Like I said, send t to me, and I'll figure it out.
It's from the program you linked to on page 1
Edit: You mean disable then reboot?
I;m talking about the program you installed that made those context menus appear., not the program i sent you.
Obviously it's an add-on,
Do you know which on e it is and can you modify it's options?
Eh... all those options have been there since I installed Firefox except for "Adblock Image..." And all the add-ons I have are the English Brittish and Swedish dictionary, SpeedDail, AdBlock Plus and FlashBlock. That's it.
When I right-click on a picture in Firefox, I don;t get those options
Then I'm stumped. I dunno what version I have but it's pretty new.
What dose yours look like then?
Go to Help > About.
You should be running 3.5,.5
Sorry, I can't capture the right-click menu
Click on Tools Addons in Firefox
Yup. 3.5.5
I just press the Print Screen button and save it in .jpg format with paint and upload it with Imageshack.us
No other add-ons that those I've already mentioned.
